DIY: Akebono BBK Installation on 03-07 G/Z
Old Feb 15, 2015 | 11:52 AM
  #121
Juan Garcia's Avatar
Originally Posted by JKL1031
i think the vanes may be. also do you have shorter banjo bolts for the brake calipers?
I'm ordering the Z1 stainless steel lines
Old Feb 14, 2016 | 07:15 AM
  #122
jznsn2u's Avatar
Awesome write up!!!
Old Jul 17, 2016 | 02:03 PM
  #123
TheIronYuppy's Avatar
Originally Posted by GreySky
Hey guys.....I am pissed and I need your help. I have been trying to find a company to make me either the Akebono stickers or the Stencils for the Akebono BBK and either get, "Sorry we cannot reproduce copyrighted logos" or in the case of vinyldecals.com they had them literally last week and when I sent them a message the response I got was "Sorry we are no longer offering those decals." WTF!!!
ANYONE have suggestions on where to get these?
I got a set on Ebay. Just do a search for 'akebono decals". They print them in the colour of your choice. Actually I have a spare set of black ones I'm not going to use. If you want black ones PayPal Me $8 and I'll mail them to you.
Old Jul 17, 2016 | 03:18 PM
  #124
JKL1031's Avatar
You want to be careful with the paper grade.
For thread record this is what I have and is lasting Also a reputable store.
https://www.tunerzstore.com/akebono-brake-caliper-decal
Old Jul 31, 2016 | 02:09 PM
  #125
I doubt there is much difference, and they are vinyl, not paper. The key to preserving them is to transfer them onto a surface which has just been cleaned with alcohol, then once they are on, hit them with a couple of layers of high-temp clearcoat.
Old Aug 26, 2016 | 12:45 PM
  #126
zenkig's Avatar
Akes looks great
Old Oct 4, 2016 | 02:39 AM
  #127
CLRH2O's Avatar
Hey there - I'm wondering about something:
If you wanted to go from Bremo's to Akebono on a 2003-2006 G35 Coupe - can you use the existing brake lines you've already got?
What I mean is this. Brembo's have a small hard line that screws *into* the back of the caliper and does NOT use a Banjo Bolt like the OEM non-Sport brakes do. (and like the shortened banjo bolt the Stoptech SS replacement lines do too). This hard line then attaches to the block connector end of the two part rubber lines which run from the suspension parts to the inner wheel well at a bracket (clipped in place by a flat spring of sorts) where it screws into the body hard line.
For that matter, are the rubber & block part of the brake lines the same on G35's, 350Z, G37 & 370Z's with the only difference being the little hard line that connects to the calipers of either Brembo & Akebono vs the rubber line + Banjo Bolt for the non-sport models of each?
And if they are different, do you need a set of the Akebono hard lines + rubber & block lines from a 370 or G37 to mate with the Akebono brakes? Or just one part of the lines and not the other?
I hope asked all that in a way that makes some semblance of sense lol!
Old Oct 4, 2016 | 07:38 AM
  #128
zenkig's Avatar
I think you just need a set of brembo stainless steel lines,but I'm not sure. Email someone at z1motor sports.com if no one on the forum answers you soon. They'll know. Sorry I couldn't be more help .
Old Oct 4, 2016 | 01:39 PM
  #129
What I mean is this. Brembo's have a sll hard line that screws *into* the back of the caliper and does NOT use a Banjo Bolt like the OEM non-Sport brakes do. (and like the shortened banjo bolt the Stoptech SS replacement lines do too). This hard line then attaches to the block connector end of the two part rubber lines which run from the suspension parts to the inner wheel well at a bracket (clipped in place by a flat spring of sorts) where it screws into the body hard line.
I used SS lines left over from a Stop Tech BBK. Not sure if this helps. I know for a fact the stock banjo bolts for the stock brakes are longer than the akebono ones. I had to grind them down about 1/8" to have them seat properly.
Old Jul 25, 2017 | 02:46 AM
  #130
03IP's Avatar
Photobucket for the loss.
Old Feb 11, 2018 | 12:34 PM
  #131
aaronelopas's Avatar
I know this is old thread but hopefully OP still looking.....
Looks like front calipers do not go all the way over rotor at bottom, and therefore portion of pad surface will not contact rotor. Is this true? I noticed a comment on Z1 saying same. This means there is a clearance issue perhaps, and bracket was designed around it, and is suboptimal....pls confirm?
Thanks!
Old Feb 11, 2018 | 01:03 PM
  #132
Ogee's Avatar
Thanks!
The caliper should definitely go all the way over the rotor, and the pad should make full surface contact with the rotor. Is it possible you didn’t upgrade to the 14” rotors?
Old Feb 11, 2018 | 01:16 PM
  #133
I have not done it yet - if you look closely at the pics you will see that the caliper is at an angle versus where a properly designed bracke t would put it - this seems to be a known issue with the kit and I am trying to get confirmation of this and whether its been fixed or not.
Old Sep 1, 2018 | 12:17 AM
  #134
Jte1998's Avatar
Hey sorry for bringing up an old post but was replacing my pads and rotors on my g35 and I thought I had stock brakes but evidently I have this akebono bbk and now idk where to buy new pads and rotors from its a daily driver mostly so any recommendations and part numbers would be great and also was going to order esr sr01 black chrome wheels front: 19x9.5 +22 and rear:19x10.5 +22 anyone know if there even fit around these calipers thanks
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
USAF_1013
Brakes
11
Feb 6, 2016 05:25 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
mushu
Jul 15, 2015 03:55 PM
