DIY - G35 Sedan Compression Rod Replacement
Old Apr 1, 2015 | 05:49 PM
  #31
JHereth22's Avatar
Originally Posted by ScraggleRock
The rubber bushings are never a good replacement idea. Gotta go poly.
And when they are installed. World of difference
Old Jan 9, 2017 | 03:23 PM
  #32
twenty5's Avatar
I sincerely apologize for resurrecting this thread. I've searched everywhere, but cannot seem to find what this part is called. It's the bracket that holds up the compression rod. Mine seemed to have broken at the pipe part. Does anyone know where I can find this part to order or what it's called in order to look it up?
I have found the part number 544C5M (LH), but it doesn't lead me anywhere when I google it.
kind regards,
Old Jan 11, 2017 | 01:35 PM
  #33
twenty5's Avatar
shameless bumparino
Old Jan 31, 2017 | 08:11 PM
  #34
Urbanengineer's Avatar
Originally Posted by twenty5
shameless bumparino
I found out I have bad bushings on the compression rods. Went for a look when swapping out the turn signal bulbs. Thanks for the bump.
Old Apr 17, 2017 | 07:18 PM
  #35
MyfistYourFace's Avatar
I believe this one comes with the sleeve and stopper, correct? Trying to make this as painless as possible...
Dorman 521-602 Control Arm
Amazon Amazon
Old May 13, 2017 | 05:50 PM
  #36
cycleguy55's Avatar
kind regards,
You've probably figured it out by now, but it's called the 'Compression rod stay' - so says the FSM.
Old May 10, 2019 | 03:56 PM
  #37
Angelv's Avatar
g35 x
help
Originally Posted by doodos
I am trying to get mine off my car and hope you guys can help me out.
I unscrewed it all but that part of the picture doesn't seem to get off. I tried pushing it down and hammering it aswell. The rod i bought doesnt have the rubber in it and its just a big hole and wondering if i would be able to reuse it
what is the name of this part?
Old May 10, 2019 | 06:49 PM
  #38
cycleguy55's Avatar
From the Factory Service Manual:
R350k5
Oct 1, 2015 08:41 PM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
