Tein Flex+EDFC+Stillen sway bar
Old May 27, 2006 | 04:18 PM
jim5437's Avatar
Hey guys,
I have the Stillen sway bars on my car already and I know they are adjustable. I'll install the Tein coilover and EDFC next week and the thing is~
Do I need to adjust the sway bars to make them fit with Coilover??
Old May 28, 2006 | 02:29 AM
ShadowG35's Avatar
Shouldn't have to in order to make them fit. Only thing you would do on your sway bars is possibly adjust the stiffness if needed after installing the coilovers.
Old May 28, 2006 | 05:26 AM
jim5437's Avatar
Thanks
Adjust the stiffness into softer? harder?
Old May 28, 2006 | 05:38 AM
Klubbheads's Avatar
Try it out and see which one u like better or fits your driving style.
Old Nov 20, 2007 | 10:53 AM
g7x5's Avatar
I know this is an old thread but does the edfc motors fit with the stillen strut bar, because im looking into getting this combination soon.
Old Nov 20, 2007 | 01:11 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I would also like to know.
Old Nov 20, 2007 | 02:21 PM
Triple8Sol's Avatar
Looking at pics of the Stillen bar, I suspect that you might run into issues. The brackets on Richie's V2 (and NRG replica) work just fine. The design of the Relentless Autosports (and GT-Spec replica) would also work.
Here's a pic of my setup:
Old Nov 20, 2007 | 04:53 PM
sliderg35's Avatar
If you have EDFC, it will not be a problem because you will not have to access the top of the shock. The EDFC motor fits all the way down in the hole where the strut connects and comes up about level with the top of the hole.
Old Nov 20, 2007 | 04:55 PM
g7x5's Avatar
thats what i was wondering do you have pic just want to be sure
Old Nov 22, 2007 | 11:02 PM
g7x5's Avatar
can anyone else verify this
Old Nov 23, 2007 | 07:29 AM
Triple8Sol's Avatar
Damn, you're needy. Look in the pic I posted above. You can see the green from the top of the coilover, and the black motor inside.
Old Nov 23, 2007 | 03:02 PM
g7x5's Avatar
yes i can see that it works with the nrg bar i was wanting to know if anyone had a stillen bar with the edfc, and im sorry im so needy, i just want to get all the info before i go and spend money
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
