Caliper Bracket Bolt Size
Old Jul 3, 2006 | 11:29 PM
jacemace's Avatar
Hello,
I need to turn the front rotors on my 05, G35 sedan. I got the caliper off but i still need to remove the caliper bracket that is preventing the rotor from coming off all the way. Can anyone tell me what the size is of the two bolts that are holding the caliper bracket in place? I'm thinking 22mm but I want to make sure. Those suckers are on their tight and I'd rather not used a cresent wrench.
Thanks!
Old Jul 4, 2006 | 12:06 AM
GLuXuRy's Avatar
22? wow that seems kind of big... i know on X5's they have a 17... just use a long 3/4 drive ratchet... and if you dont have a long ratchet use a steel pole on the end for some extra leverage
Old Jul 4, 2006 | 12:37 AM
jacemace's Avatar
I have a 20mm and it's too small. I'm thinking around a 22mm but want confirmation.
Old Jul 4, 2006 | 12:38 AM
GLuXuRy's Avatar
wow... thats a huge bolt...lol if i wasnt dressed to go out id jack my car up for ya sorry
Old Jul 4, 2006 | 09:56 AM
aszatk01's Avatar
i did this a while back.....i think it was 22 but not exactly sure.
good luck
Old Jul 4, 2006 | 11:29 AM
GLuXuRy's Avatar
ok later today im taking off my volks to get my car serviced i will check for you when i do
Old Jul 4, 2006 | 12:58 PM
GLuXuRy's Avatar
OK so i attempted to take my volks off... and the guy who put them on must of been fcukin superman... i broke my freakin snap-on breaker bar... sorry buddy couldnt get to the caliper braket... i know i could of crawled under there... but im so heated i just broke a 40 dollar tool (life time warranty )
Old Aug 31, 2006 | 09:56 PM
G356MTBB's Avatar
I removed my calipers to clean and paint them. The torque member is on there and is torqued to about 113 lbs plus the factory used thread lock on them as well. For the front a 7/8 open end wrech works best. To break them I learned my lesson that you can't use brute force as I ripped my leg on the dust shield trying to break them free. What you need to use is the wrench and then a rubber mallet. Hit the end of the wrench a couple of times, not real hard, just enough to break the threadlock and you'll be able to remove them. They're a bitch to torque back on as well so be prepared. You don't have a lot of space if you're using jack stands so you'll have to put some muscle on the torque wrench in tight quarters but it can be done.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
hrdwirk1
Jul 14, 2015 05:46 PM
