Looking for springs/shock combo with 2.5-3' drop
Old Aug 2, 2006 | 01:58 AM
GunMetal126's Avatar
I have a 04 coupe on 19's , and i am looking for a spring shock combo, or a way to get a 2.5-3 inch drop, without getting coilovers. I'm not planning on doing track so i don't think coilovers are suitable for my situation, i just want to get rid of the wheel gap. thanks in advance for any input.
Old Aug 2, 2006 | 12:12 PM
anotheraznguy's Avatar
it will be pretty much undoable. Most spring shocks will lower at most inch and a half. The only way to get it slammed is w/ coilovers.
Old Aug 2, 2006 | 02:56 PM
Do u know anything about skunk2 lowering springs, they claim 2.5'' drop, but also 1'' drop?
Old Aug 2, 2006 | 03:10 PM
Ralph0064's Avatar
the car would be virtually undriveable with a 2.5-3.0" drop. Good luck
Old Aug 2, 2006 | 03:13 PM
actually i drive my car with more than a 3 inch drop
and its a daily driver.
just don't go up driveways or anywhere with speed bumps =)
Old Aug 2, 2006 | 05:17 PM
Klubbheads's Avatar
u can get "350z Spring By Sprint" srpings which drops the 350z 1.75 all around and add .5 inch and u will be right around 2.25 inch all around. With koni shocks.
Old Aug 2, 2006 | 08:43 PM
Do you have this combination on? How are the sprint springs? CAn u pair the sprints with Tokico D-specs?
Old Aug 2, 2006 | 09:47 PM
Klubbheads's Avatar
^no i dont, just did a quick search and thats what i came up with. Yes the D-specs should work with the springs.
Old Aug 3, 2006 | 01:57 AM
Gsedan35's Avatar
I cannot express how much of a bad idiea it is to try and run shocks with that much drop. At a drop equal to 3/4" on a 350Z, special Jic bumpstops that are lower then even cut down oem bump stops, I only had 1.5" of suspension travel from the top of the shock to the bottom of the bump stop. Insuffecient for anything but nice smooth slow driving. Any faster and I got issues because the bump stops were hammering the tops of the shocks. Oh and that's with much stiffer springs, 450lbs to be exact and I have Koni's which have shorter bodies then G35 shocks, still doesn't give enough travel.
If you want that much drop, find a coilover product with adjustable height dampners that say's it has that kind of height range.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
