Hotchkis Tuning Sport Sway bars
Old Aug 24, 2006 | 01:25 PM
WYSIWYG's Avatar
Anyone have any information on the new Hotchkis Sway Bars? Quality, fit, performance? What is the best setting? They are going on an '06 w/ sport susp. Thanks for the replies in advance.
Sway bar sets include front and rear bars, greasable bushings, and brackets. Bars now come with welded retaining rings.
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Old Aug 24, 2006 | 03:53 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
yes, great, excellent, depends on driving style, personal preference.
your wlecome
Old Aug 28, 2006 | 12:56 PM
ughhness's Avatar
I run these sways with the car.
med-hard in the front and medium in the back.
I love how it drives.
I also run revised shocks from a 350z and 350z h-techs.
Old Sep 21, 2006 | 05:16 PM
bwassul's Avatar
Does anyone have the Hotchkis sways with the HKS exhaust? I'm worried about clearing the dual exhaust....
Old Sep 21, 2006 | 06:51 PM
Klubbheads's Avatar
I have the older models (3 way adjustable) on Stiff rear and medium front. I am very happy with it. No understeer what so ever.
Old Sep 21, 2006 | 07:18 PM
IQ9's Avatar
IQ9
I have the 3 ways as well and love them.
Old Sep 21, 2006 | 07:30 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
I have the older model like the previous 2 people for the past 1.5 years and love them. Much nicer ride in the corners than stock. Good price as well.
doc
Old Sep 26, 2006 | 12:51 PM
Gsedan35's Avatar
06 G35 Front
Rear:
Originally Posted by Gsedan35
All G35 and 350Z oem sway bar specs follow a more complicated path then Hotchkis's limited sampling, thus they aren't telling the whole story.
I can specifically fill in the gaps.
Group A
03-04 350Z all trim levels (car's without the revised suspension ONLY)
03-06 G35 coupe (all USDM production with oem 17 and 18" wheels)
03-04 G35 sedan (sport and non sport suspension's
All group A car's have the following oem sway bar specs
34mm front 21mm rear
hollow wall construction 5mm in thickness (courtesy of tomsn16)
Torsional rigidity Front: 1130lbs Rear:385 (courtesy BJ EVO350)
Group B
04.5-06 350Z all trim levels (car's with the revised suspension)
05-06 G35 coupe (all USDM production with oem 19" wheels)
05-06 G35 sedan (sport and non sport suspensions)
hollow wall construction 7mm front (courtesty tomsn16) 5mm rear
net change in front bar strength from 2mm increase in wall thickness
+17% (courtesty of tomsn16)
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
Jyounya
Sep 12, 2015 04:03 PM
spanky99l
Sep 7, 2015 12:46 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
