Attn: 350z tein h-tech owners...
Old Oct 12, 2006 | 10:50 PM
HXS's Avatar
HXS
just wondering if u guys got your alignment back within specs.
i'm having my alignment done in a month and debating whether i should buy the spc camber set or not.
don't know if i should buy and install them
OR
if i should let the tech try to get the alignment back into specs WITHOUT any camber kits.
Old Oct 13, 2006 | 11:25 AM
Calvin's Avatar
Overglorified Altima
its generally agreed upon that you do not need a camber kit with 350z h techs on the coupe. however, a poll revealed that 1/2 of 350z h tech owners suggested getting a camber kit.
ill try to find it for you.
Old Oct 13, 2006 | 11:39 AM
Calvin's Avatar
tried searching but i got too lazy. but heres a very helpful thread.
it has before and after pics. looks like this guys springs settled after 1.5 months, looks a lot better! initial before and after pics are on 1st page. pics after 1.5 months are on 2nd page. he also posted his #'s
Front: Left
Camber -1.2 degrees (specified range is -1.2 to 0.3 degrees) not adjustable
Toe 0.00 degrees adjusted from 0.03 degrees (specified range is 0.00 to 0.08 degrees)
Front: Right
Camber -1.8 degrees (specified range is -1.2 to 0.3 degrees) not adjustable
Toe 0.03 degrees, was 0.03 degrees before, no adj necessary (specified range is 0.00 to 0.08 degrees)
Rear: Left
Camber -1.6 degrees adjusted from -2.0 degrees (specified range is -1.9 to -0.9 degrees)
Toe 0.08 degrees adjusted from 0.06 degrees (specified range is 0.00 to 0.22 degrees)
Rear: Right
Camber -1.6 degrees adjusted from -2.1 degrees (specified range is -1.9 to -0.9 degrees)
Toe 0.07 degrees adjusted from 0.06 degrees (specified range is 0.00 to 0.22 degrees)
heres the link to the thread
https://g35driver.com/forums/showthr...=105830&page=3
Old Oct 13, 2006 | 02:08 PM
HXS's Avatar
HXS
^ tanks dood
Old Oct 13, 2006 | 02:23 PM
dream_G35's Avatar
Front: Left
Front: Right
Rear: Left
Rear: Right
so do you think if i print this out and take it to an alignment shop to see what they can do according to that would most be able to do it?
Old Oct 13, 2006 | 02:36 PM
gqong's Avatar
i was able to get mine back into specs..although i do need a re-alignment soon this was 20k miles ago..
Old Oct 13, 2006 | 02:45 PM
Steel Blue's Avatar
So Htech G35 springs would need even less adjustment?
Old Oct 13, 2006 | 03:11 PM
Calvin's Avatar
i get my alignments at firestone. dont know if you have firestones where you are but 150 (give or take 10 bucks) for lifetime alignments. great deal considering you should get an alignment every 6 months anyway
Old Oct 13, 2006 | 03:13 PM
gqong's Avatar
yeah i do have a firestone nearby but i can ive been weary about getting up that ramp. im lowered with the kurumaz front its pretty low as is. theres a town fair tire nearby that handles lowered cars witha custom ramp i am planning on going to. if you have no problem getting on that rack i may consider going there. my girlfriends jeep has the lifetime alignemnt there as well.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
