brake pad replacement - what did you do?
Old Nov 6, 2006 | 11:48 AM
bwassul's Avatar
brakes wearing, need replacement - what did you do?
I've got ~16k miles on the brakes that came with the car and am getting some squealing . What did everyone do to change their brakes? Dealership or DIY? Just pads or rotors as well?
I've got a 2005 w/ the non-Brembos. I also don't have an interest in a BBK upgrade because this is just a daily driver.
Old Nov 6, 2006 | 12:03 PM
SilverII's Avatar
got mine changed under warranty at 30K (pads & rotor). Your 05 does not have brake warranty.
Now I am running PMU front/OEM rear. I did the install myself. Easy DIY
Old Nov 6, 2006 | 12:41 PM
bwassul's Avatar
How do I know whether to change the rotors as well or just the pads? Do the rotors get turned if I keep the ones I have?
Sorry for the noob questions..first car trying to DIY as much as possible .
Old Nov 6, 2006 | 01:19 PM
richie's Avatar
you could take off the wheel and just check the wear on the pad.
as far as rotors getting turned, i dont think you need that this early in the game
Old Nov 6, 2006 | 03:21 PM
Q45tech's Avatar
Rotor can warp or just get uneven pad deposits in 5,000 miles you never know unless you measure the rotor runout...........spec <0.0028".
Old Nov 6, 2006 | 03:41 PM
GReddySetGO's Avatar
Turn your rotors if you get new pads.
If you want someone to take a look at them for you, to even see if you need new pads or not yet, I can do it for you. 16k is pretty early to be done with pads.
Old Nov 6, 2006 | 04:40 PM
emtguy05's Avatar
i got about 58,600 miles on mine and i'm getting the Hawk Performance Ceramic pad for my daily driving. Im also getting the Cryo treated power rotors
Old Nov 6, 2006 | 05:12 PM
GeeMan's Avatar
I will probably go Powerslot cryo rotors and Endless Vita Nuova pads
Old Nov 8, 2006 | 01:30 PM
cSc's Avatar
cSc
I need to replace my pads also. I'm at 2mm front and 3mm rear remaining with the original 2003 Brembo brakes and just under 40,000 miles.
However, I went to the dealer and they are quoting me $1050 for replacement pads and for just *resurfacing* the rotors.
From what I can find, I can get a 2 sets of Hawk pads for under $200. So are they charging me $800 in labor to install and resurface? When comparing the prices of rotors, I could have pads AND rotors replaced for about $1050...
Also, it was intersting to hear from TireRack.com that I only have Brembo calipers with generic pads and rotors. I thought we had Brembo pads...anyone else already know this?
--cSc
Old Nov 8, 2006 | 02:55 PM
RocketG35's Avatar
Why do I bother to DIY???
I have the same brake pad (Project Mu NS/OEM) set up on my 03.5 sedan...I like the stopping power and minimal dusting. And yes, very easy to do...
Old Nov 8, 2006 | 04:08 PM
SilverII's Avatar
I actually have the PMU b-force. I bet they dust more than the NS.
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
emorehs
Jul 17, 2015 09:45 AM
