Anyone install EDFC themselves on coupe?
Old Feb 2, 2007 | 03:08 PM
afr0puff's Avatar
Supa Dupa Moderator
Originally Posted by GReddySetGO
There is one there. Use a test light. There is also one in the ignition switch.
Am I doing it wrong? I connected the ground to the frame, and I prodded each opening with my test light to see if it would come on. I did this without the key turned.
I used the same method, except with the key turned and the lights on, to find the acc power and illumination from the heated seat switches.
I've got an 03 6MT, if it matters.
Old Feb 2, 2007 | 05:07 PM
GReddySetGO's Avatar
Thats odd. I wish I had a car apart here at the shop so I could tell you which wire it is. But I know for a fact that there is a constant power source from behind the hazard switch. You are testing it correctly, with the key off and out of the ignition. There for sure is a source there, because you can use your hazard lights with the key out.
How are your probing the connector? Try unplugging the connector and probing it from the front at its contact points.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
lemmy999
Jul 25, 2015 12:13 PM
Ashton35
Jul 22, 2015 09:19 PM
