View Poll Results: wat problems r u having?
installed spacers, have ABS, Slip, VDC lights on
29
18.01%
installed spacers, have knocking
4.35%
installed spacers, have both lights and knocking
3.73%
didn't install spacers, have no problem
40
24.84%
didn't install spacers, have one of the problems above
4.35%
didn't install the camber kit yet.
43
26.71%
installed spacers, no problem
29
18.01%
Voters: 161. You may not vote on this poll
SPC Poll
Old Oct 29, 2007 | 10:31 AM
  #271
THMotorsports's Avatar
Originally Posted by G35Rider92649
Installed front camber with spacers here.
Big problems. Car drives like s**t.
VDC Lights, Slip, and ABS on, what do i do.
Already ran an alignment, didnt help.
What now?
SCREW G35 SUSPENSIONS, THEY ARE A JOKE
SCREW SPC, THIS IS A JOKE
THMOTORSPORTS IS BADASS THO, I LIKE EDDIE!
Haha, very very funny. everything should be smooth as butter and rich like gold!
Old Jan 14, 2008 | 08:23 PM
  #272
str8dum1's Avatar
same story here, revised arms + spacers = abs/vdc/slip. i'm going to try moving the sensor around some.
how long do you have to drive before the lights shut off, if all is good?
Old Jan 14, 2008 | 08:39 PM
  #273
Boston's Avatar
I installed the spacers and I got the VDC, SLIP and VDC lights. The lights went out after turning the car off but I've gotten the lights three times since the install but they always reset themselves. I went 4 weeks without a knock but it's there now. The knock occurs when I hit medium bumps, pot holes or man hole covers. The knock sounds like a bad shock bottoming out. The coilovers are new and were installed with the SPC arms.
Old Jan 14, 2008 | 08:46 PM
  #274
Gilley's Avatar
If you adjust the sensors properly, the lights will remain off immediately.
Old Jan 14, 2008 | 08:57 PM
  #275
str8dum1's Avatar
so with the bracket, theres a couple mm play left or right. i just bolted the bracket up. I dont understand why it wouldnt be right from the start??? WTF. nothing was bent or abused.
is really the only way to determing the correct postion by pulling the hub again and the plastic piece?
Old Jan 14, 2008 | 09:51 PM
  #276
Gilley's Avatar
You don't have to pull the hub. Make sure the wheel spees sensor bracker is lined up in the middle of the round pick up ring on the back of the hub.
Old Jan 14, 2008 | 09:56 PM
  #277
str8dum1's Avatar
update-- all fixed. just wedged the brackets out a hair and all good.
Old Jan 17, 2008 | 07:41 PM
  #278
_GRide35_'s Avatar
I too have the same problem with the three lights and will try the sensor re-alignment this weekend. Can someone explain how to align the sensor? Should I remove the sensor and re-install it or just loosen the bolt and find it's sweet spot?
Old Jan 17, 2008 | 07:47 PM
  #279
str8dum1's Avatar
all i did in my case was take a flat blade screwdriver and and wedge the sensor bracket out a hair.
Old Jan 17, 2008 | 07:48 PM
  #280
Gilley's Avatar
Loosen the bolt and try to keep it centered on the pick up ring while you tighten it.
Old Jan 17, 2008 | 08:44 PM
  #281
_GRide35_'s Avatar
Cool, thanks for the quick reply guys. Should I keep the display lights on and have someone monitor them until they turn off or does it have to be turned off so that it resets when turned on?
Old Mar 5, 2008 | 10:49 AM
  #282
surfquikslver's Avatar
im wondering the same thing that that guy^ asked...If the sensors line up correctly the light will turn off immediately. Im assuming theres 2 sensors so it would only turn off once both are in the right position right?
Old Mar 5, 2008 | 10:51 AM
  #283
MIA BlazinVQ's Avatar
brb getting cut
wait what's with all this spacer talk and such? why do we need spacers with the kit?
Old Mar 5, 2008 | 12:56 PM
  #284
I dont know man, im confused too. All i know is i wish my abs/vdc/slip lights would go off. My car has been driving like a pig for the past 2 months with these lights on.
Old Mar 6, 2008 | 11:36 AM
  #285
IAPDirect.com's Avatar
Hello Guys,
Thought I would chime in here. The spacers included with the SPC kit are designed to increase camber adjustment by 2 degrees. When doing so, you must install the abs sensor spacers to keep the spacers exactly where they were before the installation. The sensors are very sensitive and must be in the same location to pickup the signal from the hub.
Therefore, if the sensor spacers are simply bolted up, you will be fine. If the spacers are bent during installation, the sensors will not be positioned correctly and your dash will light up. If you are having this issue, the spacers were not properly installed so take your vehicle back to the installation shop and ask that it be corrected.
Please PM me if you have any questions. I will be more than happy to assist.
