simplest way of lowering '05 coupe...
^^ agreed; the '05 19" coupes have stiffer rear springs, so you may want to consider the revised z springs to keep your spring rate similar (ride feel) and still get the drop. you may also want to consider getting the corresponding z dampers with the springs. you can often find a lightly used set of dampers and springs for a good price.
search the forums on revised springs and you will find lots of good info to consider.
Most people who got the z-springs for the 05/06 w sport suspension got little to no drop in the rear, so that may or may not work depending on your setup. I don't recall who did it, but maybe search and see who performed this mod, and PM them to see if their springs finally settled to a reasonable drop
Originally Posted by mixturepinoy
cut the springs!
Originally Posted by rjcs03
mixture pinoy, your jokin ryt? if you cut the springs, it wont perform as good as before... and prolly cause your suspension and others to break...
pinoy too huh...
pinoy too huh...
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
