Tein CS VS Tein SS
Old Nov 20, 2006 | 02:41 AM
cloud's Avatar
Tein CS VS Tein SS
What's the difference? they have the same spring rates... just different tube constructions. Mono & Twin. Which is better? Anyone can clear this up for me ?
Also, do I need a camber kit if I plan to install the coilovers but not drop the car?
Thanks
Old Nov 20, 2006 | 02:49 AM
GReddySetGO's Avatar
Spring rates are only half the story. The valving inside the damper is diffrent for both.
CS is a softer ride, similar to stock. Even on its hardest setting it will not be much stiffer than stock.
SS is a little more performance oriented, but still maintains a good comfort level on its softer settings. On its hardest settings it will be stiffer than stock and you will be able to notice a performance diffrence.
If you do not lower the car at all, your probably won't need a camber kit with these.
Old Nov 20, 2006 | 12:57 PM
cloud's Avatar
I got quoted $600+ for installation of EDFC & coilovers at ZCG
$725 including alignment ... isn't that overkill?
Old Nov 20, 2006 | 03:48 PM
nm3th's Avatar
^^^For that price, are they throwing in any lube?
Old Nov 20, 2006 | 03:58 PM
^ Wow, that is pretty pricey, but it is a very intensive install. Too bad you're not in SoCal, I would install it for cheaper for you =P
Maybe if you order those coilovers, you can come down to pick them up. Save on shipping, and save on the install...
Old Nov 26, 2006 | 03:54 AM
04Rg35's Avatar
Where would i be able to get my hands on the SS system?
Old Nov 26, 2006 | 06:37 PM
cloud's Avatar
GreddySetGo can get you the SS. Give him a PM he has been real helpful.
Old Nov 26, 2006 | 07:02 PM
caelric's Avatar
On the softest side, for the SS, are they harder or softer than stock?
Old Nov 26, 2006 | 10:08 PM
On its softest setting, its probably very close to stock.
Old Nov 26, 2006 | 10:34 PM
caelric's Avatar
I'm looking for something slightly softer than stock for when my wife rides, slightly stiffer for everyday driving, and somewhat stiffer for a track day. I've pretty much decided on the CS w/EDFC, but I am still trying to get opinions, as I haven't spent the money yet, and probably won't until after the New Year
Old Nov 27, 2006 | 03:37 AM
If you want something that will be softer than stock, the yes, Tein CST is your choice.
Old Nov 30, 2006 | 06:07 AM
IngsG's Avatar
Are you kidding me? There is no way Tein CST is softer than my stock suspension.
Old Dec 1, 2006 | 02:33 PM
FonkiMonki's Avatar
Thanks
The main difference between the Mono Tube and Twin Tube design is the mixture process of oil and nitrogen within your shocks. With a Twin tube design, you will have more chances of aeration. With a mono tube dsign, you will have less chances for that. Mono - type design are made more for the track guys that are looking for optmize performance and longivity over extensive abuse of the coilover system.
Second, the valving is a lot less aggressive on the CS vs. SS. The spring rates might be the same, but the valving can be completely different.
Hopefully this will help to answer your questions!
Old Jan 31, 2007 | 05:07 PM
ttrank's Avatar
Grocery getter
I will be installing a set of CS in the next couple weeks. I can update this then.
KruZZe
Feb 27, 2023 05:04 PM
nissandrifter32
Dec 22, 2015 04:28 PM
bigmike
Sep 17, 2015 01:58 PM
