350z or G35 (S or H) Tech AAGGHHH
Old Jan 4, 2007 | 07:13 AM
  #61
wadd3456's Avatar
Rut-Row, that was a late response
They are going to arrive TOMORROW! CRAP!
Old Jan 4, 2007 | 02:40 PM
  #62
G-MENTED's Avatar
if you have the money... of course coilovers are the best way to go.
Old Jan 4, 2007 | 06:58 PM
  #63
ke104's Avatar
Wadd3456 Did you go with the 350z or G35 STechs?
Old Jan 4, 2007 | 07:01 PM
  #64
Calvin's Avatar
Overglorified Altima
he got g35 s techs
Old Jan 4, 2007 | 09:11 PM
  #65
wadd3456's Avatar
Yes sir
Old Jan 8, 2007 | 03:23 PM
  #66
1hoTrEdG35's Avatar
ANyone know anything about cutting the upper rubber mount when installing springs? I did an s tech install on my coupe, and the drop is no where near the advertised drop. I also did not cut the bump stop, i know that has nothing to do with ride height, but did i make a mistake somewhere? I read that you dont need to cut the bump stop, but the car droped 3/4 of an inch in the front, and i cant even notice the drop in the back. WTF?????
Old Jan 8, 2007 | 04:41 PM
  #67
jpez179's Avatar
Did you get the G35 or 350z stechs? How long ago ..give time for them to settle. Did you install them correctly...if they are seated incorrectly you will defentally not get the drop...sorry i might be saying the obvious..I have the G35 s techs and the drop looks correct.
Old Jan 9, 2007 | 08:39 AM
  #68
1hoTrEdG35's Avatar
I have the G35 S Techs. I put them in on Saturday, i didnt get a change to drive the car cause its still in the shop waiting to be painted. Im pretty sure everything is done right. Im hoping that the springs just need time to settle. i didnt move the car much at all. Are you still on stocks? I have seen the same springs on many coupes, and none of drops look the same. User Nismoboy's car looks great, but my car is sitting no where near his drop, and he has the exact same thing.
Old Jan 11, 2007 | 03:00 PM
  #69
jpez179's Avatar
Tried to get my alignment dont yesterday..but my car was to low for the lift..lol do you guys know any nation wide shops that can do alignment on lowered cars?
Old Jan 11, 2007 | 03:09 PM
  #70
Calvin's Avatar
where are you located? do you have a body kit?
my friend with a kenstyle kit and lowered on coupe s techs was able to get on the lift at firestone
Old Jan 11, 2007 | 06:57 PM
  #71
wadd3456's Avatar
jpez, how low is low? When you DO get it aligned, can you post your before and after specs please.
Make sure to tell them you want the before specs or they wont print it out for ya. Thanks!
Old Jan 17, 2007 | 05:44 PM
  #72
jpez179's Avatar
Here are my specs after the allginment
Front left
  • Actual Camber = -1.7
  • Actual Caster = 8.2
  • Actual Toe = 0.0
  • Actual SAI = 5.6
Front right
  • Actual Camber = -1.6
  • Actual Caster = 8.3
  • Actual Toe = 0.0
  • Actual SAI = 5.5
Rear left
  • Actual Camber = -1.9
  • Actual Toe = -0.01
Rear right
  • Actual Camber = -2.2
  • Actual Toe = -0.65
Im a degree or two off on some of these things how bad will this ware my tires??? How much is a degree??? And what is SAI Thanks guys..
Old Jan 18, 2007 | 05:19 PM
  #73
wadd3456's Avatar
Your camber isnt great but not too bad. What do you mean by "how much is a degree?"
SAI is steering axis inclination. http://www.familycar.com/alignment.htm
Did they give you the before specs? Im interested to know if they did squat.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
