350z or G35 (S or H) Tech AAGGHHH
Old Dec 2, 2006 | 01:52 PM
jpez179's Avatar
Question 350z or G35 (S or H) Tech AAGGHHH
AGGGHHHH.....Wel hopefully this thread will help all of those in search of springs. So lets get started...In a couple of weeks I will be recieving my rims I ordered form Status (THanks Alex !!!). So I'm deciding to drop the G so it doesnt look like a 4x4. Ive searched and searched and searched..In have recived alot of good but conflicting information so hopeflully we could put these questions to rest!!!
1)For the 350z S - tech will you need a Front and/or Rear camber kit?
2)For the G35 S - tech will you need a Front and/or Rear camber kit?
3)For the 350z H - tech will you need a Front and/or Rear camber kit?
4)For the G35 H - tech will you need a Front and/or Rear camber kit?
5)Average cost for 350z S - tech?
6)Average cost for G35 S - tech?
7)Average cost for 350z H - tech?
8)Average cost for G35 H - tech?
9)Average cost for a front camber kit?
10)Average cost for a rear camber kit?
I know these are alot of question but hopefully this thread well help people cut throught all of the bs and save some tires and money...Thanks everyone for your future post!!!!
Old Dec 2, 2006 | 02:07 PM
filanj's Avatar
it depends on what you are going for... do you want to get cambers?
I hope Cal doesnt mind me quoting him, but he helped me out a lot with this....
Originally Posted by aHero4Eternity
tein s-techs (for the g35) will give you a pretty aggressive drop. tein h-techs (for the g35) will give you a very very sublte drop, but it should still be noticeable. at least to a g35 driver. but imho, g35 h-techs give you such a sublte drop its not even worth it. ive never heard of/seen anyone dropped with 350z s-techs so i cant provide any info on that except that i would assume that is going to be an aggressive drop as well. one of the most popular choices on the forums are the 350z h techs. this will give you approximately -0.8f/-0.7r drop. for this, you should be fine with stock shocks, but lots of people like to upgrade to tokico d-spec anyway. imo, its not necessary. the general agreement upon people is that you will not need a camber kit as long as your dro is less than 1 inch. so for the 350z h techs you should not need a camber kit. for the g35 s techs (-1.2f/-0.9r) you do not NEED a camber kit imo unless your negative camber is really bad and you cant get it into factory specs. for the g35 s techs, i would recommend getting a camber kit but its not absolutely necessary imo. though you will get better tread life if you get the camber kit.
so to sum it up..
anything less than a 1" drop you should not need a camber kit/shocks. you should be fine with just the springs.
anything more than a 1" drop you should definitely get a camber kit, imo. the only exception to this is the g35 s techs, imo. those you will want to consider a camber kit but personally i dont think you NEED it.
from what i understand, tein springs seem to be the most popular because most people like the comfort/looks of the drops they offer. if im not mistaken, other springs such as eibach and tanabe pretty aggressive and you will want to get camber kits for those.
hope that helps a little...sorry if its confusing..im tired from studying for midterms..
maybe i can answer your question more clearly tomorrow, lol
good luck
btw, my choice of springs were the 350z h techs
oh yeh, and springs can take anywhere from 2 weeks to a 1.5 months to fully settle..so i am getting a lifetime alignment from firestone so i can align my car as many times as i want whenever i want..ive had my springs for about 2 weeks now and will be getting my first alignment this week, hopefully, and another in 4 weeks.
another example of Hero contributing a wealth of info to the community
as per pricing.... I'm pretty sure this company is the one that if you call them up and tell them you're a forum member they will give you a discount... not pos these guys are them though.... http://www.jscspeed.com/350z/350z_base.html
Old Dec 2, 2006 | 02:22 PM
Calvin's Avatar
Overglorified Altima
filanj, thanks for quoting me. but after rereading that right now...i think i contradicted myself a couple times in there like i said, it was late and i was tired from studying for midterms
i would assume yes, but idk because ive only seen 1 or 2 people dropped with these springs
you dont need one but youll probably want one to maxamized tire life. if anything, youll want to get the rear camber kit.
you should be able to get the rears back into spec. but since you cant really adjust the front, youre kind of screwed there. most people with z h techs dont get any camber kit. the front will be out of spec but not by too much.
no. this is a very subtle drop iirc.
150ish - depending on where you go you can finder lower or higher
jscspeed - 139 shipped to your door. if you get them from someone else, expect to pay around 150ish.
too much for me (at the moment). also needs to consider the brand...
lots of people get the spc. i think it's on sale right now for 200 or so
check this thread. i found it to be very helpful.
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
Old Dec 2, 2006 | 02:31 PM
Calvin's Avatar
also take into consideration...
with an aggressive drop you might need to roll/shave your fenders - depending on your wheel size and offsets too. some people have a problem with rolling/shaving their fenders but imo it's not that big of a deal
and ride quality. spring rates are different for z h/s techs and g h/s techs.
if you wanna slam your g...look into eibach/tanabe springs.
or...if you have the money...coils
Old Dec 2, 2006 | 02:53 PM
Hexxum001's Avatar
Just get Tein coilovers.
Old Dec 2, 2006 | 02:57 PM
Calvin's Avatar
hey hexx, wanna donate some tein flex to me?
Old Dec 2, 2006 | 03:21 PM
O HELLA JDM's Avatar
uhmm i think im gettin h tech z springs... by next year around feb....wait so cal you just but 2x4 in ur car and leave it in the trunk...cuz by next month il have the frotn lip then ill save up for a drop...then after that new rims....sound like a good plan or should i change it around a lil... ....go get the Z h-tech its stiffer and a bigger drop
Old Dec 2, 2006 | 03:39 PM
redlude97's Avatar
I second the use of Z H-techs as well, but its not an even drop so to fix it, trim the rubber springmounts 1/4-1/2" in the rear. The SPC rear camber kit can be had for <$200 also so I don't see why it shouldn't be install to save your tires. You may be able to get back within the stock specs without a camber kit, but the specs are so wide that it won't mean your tires won't wear evenly. The ideal alignment spec is right in the middle of the specs, which you won't be able to get back to without a camber kit.
Old Dec 2, 2006 | 05:15 PM
jpez179's Avatar
great post everyone!!! I hope this helps others about to buy some springs!!!!
Old Dec 3, 2006 | 12:43 AM
HXS's Avatar
HXS
cal,
are these guys in this forum?
Old Dec 3, 2006 | 10:51 PM
Calvin's Avatar
yep. but i have no idea who they are. bad memory
Old Dec 3, 2006 | 11:14 PM
jpez179's Avatar
Im not sure if this might help some people on deciding which springs to get...but it would be nice if we had some pics of each spring installed...just a thought lol
Old Dec 4, 2006 | 03:34 AM
shimmy's Avatar
Here's some for 350z H Tech (which I am running). I highly recommend these springs
https://g35driver.com/forums/brakes-suspension/105830-05-6mt-coupe-tein-350z-h-tech-install-pics-before-after.html
Old Dec 4, 2006 | 05:32 AM
G-Ride Canada's Avatar
one question from a newb....
if the car dropps lower than 1.5'', will the stock suspension handle it? or
should get a coilover?
Old Dec 4, 2006 | 06:26 AM
Nismo G's Avatar
If you want i have a brand new set of g35 H-techs in the box. $120 shipped
