Hawk HP brake pads
Old May 1, 2007 | 12:21 AM
  #31
filanj's Avatar
Originally Posted by G35ANSTA
This wasnt true for me, my brembos squealed when they were new and got better as they wore down.
That is very interesting. Mine had the adverse affect.
Old May 1, 2007 | 12:29 AM
  #32
G35ANSTA's Avatar
Well, to the best of my recollection the brembos squealed alot new and then got better after 5k miles or so and then probably got nosier again after 20k. Look it is a known issue that the brembos make noise sometimes, this is probably why infiniti stop using them. I think think they got too many complaints about premature wear and excessive noise. I do remember specifically that the brembos seemed to sueal the most at low speeds and light pressure. They definitely did not squeal when I was slammin them! And, once and for all I think the Oem pads do have a better bite than the hawk pads, but overall performance is very compatible and less dust and noise is obvious.
Old May 10, 2007 | 10:01 AM
  #33
glennmead's Avatar
I would suggest trying the RacingBrake brand. They offer a nice range of pads so they can match your needs. For street and light track use I recommend the 700 sereis. I've used them on the track and on the street. No noise. The Hawk pads make a lot of noise, to the point they are embarrassing.
Old May 10, 2007 | 02:56 PM
  #34
G35ANSTA's Avatar
Glenmead, at what point did they squeal and what setup do u have? I just purchased a set of 1 piece Rotora cd/s rotors w/ Hawls hps. I have no squeal at all and i have put 400 miles on them already. I really think its the brembo oem pads and rotors that create the noise the most. The hawk pads are comparable to the brembo oems but with less dust.
Old May 11, 2007 | 10:44 AM
  #35
glennmead's Avatar
275 Azenis on all four corners
Hotchkis springs and sway anti-sway bars
G35 Brembos front and rear
RacingBrake 2 piece rotors on the front
Bear Frozen rotors on the back
ATE Super Blue brake fluid
SS brake lines
I use the SS factory shim to reduce heat transfer from pad to caliper
I have also 'crowned' the caliper pistons to reduce heat transfer to the caliper.
The Hawk pads I was running were the HP+ (front and rear). They squealed very loudly below 5 mph, which means every stop light and stop sign. I went through two sets before I gave up on them (I track my car so I go through lots of brake pads). They were fine other than that. I've run 500, 700 and 900 series RacingBrake pads with no squeal at all. I would not recommend running the 900's on the street. I wouldn't recommend running the 500's on the track.
Old May 11, 2007 | 12:29 PM
  #36
G35ANSTA's Avatar
SS brake lines
The rotor and pad combination might be the problem. I really think that the hawk pads are much harder on rotors then the brembo pads. Perhaps your rotors are tough on pads, so this may cause noise when used in combo w/ hard pads.
Some people may disagree with me but i really think u can only have it one way, either ur pads outlast the rotors or ur rotors outlast multiple pads. If u purchase soft pads then ur rotors will last a little longer, but of course ull get more dust from the softer pads. The opposite is also true, if u buy harder pads theyll last longer but they will eat up ur rotors alot quicker.
Old May 11, 2007 | 07:38 PM
  #37
glennmead's Avatar
Hmmmm. I don't have a braking problem, I was answering someone elses question about what I was running.
Old May 12, 2007 | 12:30 PM
  #38
G35ANSTA's Avatar
Im not saying u have a problem. I am addressing the problem with hawk pads making noise, etc.
Old May 14, 2007 | 06:26 PM
  #39
traian's Avatar
Hawk HPS versus HP+
I'm new to researching the Hawk pads but I saw references to Hawk HPS and HP+. What's the difference and which one is better ?
Old May 15, 2007 | 10:00 AM
  #40
Q45tech's Avatar
Researching or reading the promotional literature.
Important to KNOW the friction coefficient of pads vs pad temperature and the frictiction coefficient vs application speed. New, and at increments of wear and age from heat cycling.
Wear rate vs temperature in milligrams per second.
These are the trade secrets pad marketeers hope to hide from public so they cannot make informed valid comparisons.
Old May 23, 2007 | 11:13 PM
  #41
martinS's Avatar
How come nobody mentioned the OEM brembo pads from everythingg35.com?
Alright, how come nobody mentioned anything about the OEM brembo brake pads from everythingg35.com? Is it because they don't really have them (ie. just forget to take it off their website.)?
I am looking for Brembo OEM replacement pads too (I have 04 G35 6MT). Have been thinking about the ones from everythingg35.com. But I have never dealt with them, don't know how they are in terms of shipping speed and charges, ect. Don't even know if they have them, since the OEM brembo pads are so hard to get. ( someone said brembo only sell those to infiniti dealers??)
Has anyone here tried to buy those OEM brembo pads from them? what was your experience?
Thanks for your input.
Old May 23, 2007 | 11:15 PM
  #42
martinS's Avatar
here are the links to the pads i was talking about above.
http://www.g35parts.com/9083/osc/pro...roducts_id=205
http://www.g35parts.com/9083/osc/pro...roducts_id=204
Old Jun 24, 2007 | 04:31 PM
  #43
flyt89's Avatar
hey does anyone know if the pads are the same on the 2005 g35x and the 2005 g35 coupe automatic. both with standard brakes. i have a set of hawk hps pads hb268f.665 d815 and my mechanic said that dont fit. any input would be greatly appreciated thanks.
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
