Cross-drilled or slotted Brembo rotors ?
Old Jan 2, 2007 | 11:15 PM
traian's Avatar
I'm getting ready to replace my front Brembo rotors/pads (on my 04 Coupe) and I read about cross-drilled and slotted Brembo rotors types.
Which type would you recommend (the price seems to be the same) ?
Old Jan 3, 2007 | 09:52 AM
Diesel1's Avatar
Moderator
Cross drilled for looks, slotted for performance. That's basically the long and short of it!
Old Jan 3, 2007 | 12:00 PM
StopTech's Avatar
X-drilled rotor have a tendency to crack when put under higher stresses. Afterall, you have holes in a solid structure.
The rotors that go on the Brembo system have a pillar vane design, meaning there aren't straight vanes, but posts inside of the rotors. I'd be very careful of the drilled rotors on the stock Brembo system. If one of the drill holes is placed right on a pillar, it creates a weak point.
Old Jan 3, 2007 | 12:50 PM
Potty_Pants's Avatar
stick with slotted
ppp
Old Jan 3, 2007 | 01:25 PM
maxximase's Avatar
Neither for a street car, unless you don't mind paying a little extra for the look. Plain old solid rotors will work just fine on the street.
Old Jan 3, 2007 | 11:53 PM
sage's Avatar
Just wondering, should someone doing average stree driving really be concerned about this?
Old Jan 4, 2007 | 12:02 AM
Aman's Avatar
For street driving, I would stick with plain rotors, slotted rotors wont be unsafe or anything, but will create more dust and make more noise as they continuously scrape the pad surface when braking.
Old Jan 4, 2007 | 12:34 AM
Triple8Sol's Avatar
Xdrilled/Slotted. I've run this on my last 2 cars, through daily driving and many AutoX sessions. It's fine.
Old Jan 4, 2007 | 02:41 AM
traian's Avatar
Thanks a lot for your comments. It looks like I should be going with "slotted" rotors. Would the "slotted" rotors require special brake pads or not ?
Old Jan 4, 2007 | 01:51 PM
StopTech's Avatar
I'd be concerned, cause I know we all like to womp on our cars once in a while. Grandmas and Pure roll around show cars don't need to be concerned. No offense to grandmas.
Old Jan 14, 2007 | 05:23 PM
OMyG's Avatar
Why are you replacing the rotors? They are anything but cheap and work well for all but medium to heavy track use. If you have not resurfaced them and they aren't cracked, put the $$$ to better use. Get the machine shop to cut them and install new pads.
Old Jan 18, 2007 | 01:35 AM
traian's Avatar
The width on my rotors is 28mm which I was told is the minimum allowed. I have 54k miles on my original Brembo brakes/rotors from the factory. According to the dealership, I won't be able to resurface the rotors, hence I need to replace everything (pads and rotors) in front.
After doing some searches, I found a pair of rotors, either slotted or cross-drilled, to be around $375 which is better than $510 per rotor which is the dealer price. I'm not sure if I need special pads to go with a slotted versus a flat-surface rotor.
Has anybody else bought original Brembo rotors and pads and if so, from where and how much was it ?
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
