G35coupe spring/shocks lower 05 sedan?
Old Jan 9, 2007 | 11:52 AM
teedo's Avatar
I was wondering if the G35coupe spring/shocks will lower my 05 sedan? I don't know if that brembo package on the coupe has a sport suspension so i was wondering if it has any effects on the sedan handling and stance wise...
Old Jan 9, 2007 | 11:59 AM
az1anbeethoven's Avatar
the coupe springs will lower your car by 0.5"
Old Jan 9, 2007 | 12:12 PM
teedo's Avatar
are the spring rates for the 03 coupe and 05 sedan same?
Old Jan 9, 2007 | 12:14 PM
ttrank's Avatar
Grocery getter
I don't think so.
Old Jan 9, 2007 | 12:15 PM
jameyb's Avatar
Yes. As long as you get springs from a coupe that does not have 19" wheels you will be good. EDIT - this applies only if you have the sedan sports suspension.
See this post:
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
Here is a measurement for the rear:
https://g35driver.com/forums/g35-sedan-v35-2003-06/109021-installed-unrevised-z-springsyesterday.html
I don't have one for the front because I am running Z front, coupe rears.
Old Jan 9, 2007 | 12:17 PM
teedo's Avatar
well i do not have the sport suspension and i didnt come with oem 19s... do you think the swap would be reasonable? and if i just changed the springs would that be okay or would i have to worry about future problems like dead shocks?
Old Jan 9, 2007 | 12:20 PM
jameyb's Avatar
If you don't have the sports suspension you will kill your shocks faster than normal according to others experiences. If this is the setup you want consider buying a full coupe suspenion (i.e. including shocks/struts) or upgrading shocks.
Old Jan 9, 2007 | 12:24 PM
perry05G35's Avatar
Yes since you are going to purchase the springs and shocks you are safe. If you found a coupe selling the springs already mounted on the shocks then it's plug and play for any suspension shop should take less than 1 hour.
People say the coupe springs will drop a sedan 1/2 inch but I think it's will drop the sedan a little less than the 350z springs and more than 1/2 inch. I say that because I have the Coupe springs in the rear and I got the same 1 inch drop as my eibach's gave me. If you install the coupe springs at all 4 corners post pixs since I think you will be the first sedan to do it...
Old Jan 9, 2007 | 12:27 PM
teedo's Avatar
thanks and I will
Old Apr 16, 2007 | 11:30 PM
labguy94's Avatar
bump - for update.
teedo: did you ever get the coupe suspension for your sedan? How is the drop? pics? I too am running non-sport suspension and am looking for a mild drop. I'm considering the full coupe suspension.
thanks in advance!
Old Apr 17, 2007 | 08:37 AM
devster's Avatar
I have 07 coupe springs and I am waiting on 05 coupe shocks, both from the 6MT 19" Wheel package, so we will see how it turns out. I am matching the same shocks & springs so it should be fine.
Old Apr 17, 2007 | 03:05 PM
labguy94's Avatar
Thanks for the info devster. Please let us know how it turns out. Please also post pics.
Old Apr 19, 2007 | 03:01 PM
teedo's Avatar
Originally Posted by superkid94
bump - for update.
thanks in advance!
sorry i havent done it yet. i was also thinking of getting a new car so i kind of stopped with any mild modifications. i'm still thinking about keeping the car or not. i want a manual because i want to TRACK MY SEDAN
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
mann1961
Aug 9, 2015 08:44 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Kal Hamm
Jul 24, 2015 08:55 AM
