Just got BBK, need spacers now
Old Feb 2, 2007 | 07:17 AM
cato's Avatar
SouthernComfort Moderator
Originally Posted by Moog
Just picked up a used set of Brembo GT brakes (not the OEM Brembos). These things clear but only have enough clearance to barely fit a sheet of paper through, so now I'm thinkin about some 5mm or 8mm spacers. U guys have any experience w/ those Ichiban spacers w/ new studs?
I had the same experience with my 6-pot Wilwoods. After they heated up, they expanded and started shaving the wheel spokes. I bought 3mm spacers and all is fine now. Get the 3mm spacers. When it gets hot, you will have no clearance and will start shaving the outside of the calipers. The 3mm spacers did not require new wheel lugs or nuts.
Old Feb 2, 2007 | 07:35 AM
ma_sha1's Avatar
Another option is to get 2mm spacers. I got a set on ebay.
I have 0.5mm clearance after spacers. No rubbing problem after 6 month.
My wilwood 13.6 BBK also runs a lot cooler than stock.
Old Feb 2, 2007 | 12:55 PM
Andy@Performance's Avatar
Originally Posted by Sundeviljay
i have stop tech 4 piston all around
You should be fine then, just make sure there is a decent amount of clearance.
Old Feb 5, 2007 | 07:24 AM
cato's Avatar
I would have gone 2 mm, but could not find them anywhere.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
