Tanabe NF210 or GF210's...
Jan 31, 2007 | 07:07 PM
Anyone got pics of their ride with either of these springs? Preferably w/stock OEM 19" Rays.
I know the front drop is identical on both sets...
Another question if you have either...how often do you find yourself angling out of driveways?
Reply 0
Jan 31, 2007 | 07:10 PM
considering I have to angle out of all driveways now with only 350z-htechs, I would say plan on angling over everything from now on
Reply 0
Jan 31, 2007 | 07:31 PM
Since the wheel base is long you find your self having to angle even at stock ride height I feel...
Once you do it a bit you do it naturally... And you find your self avoiding the steep drive ways...
Reply 0
Jan 31, 2007 | 07:32 PM
i dont think the gf210's are made for the coupe.
they have nf210 and df210 for the coupe tho..
not sure what you have...id go with the df210s though
i angle it every single time. better safe than sorry. i'm also on z h techs.
Reply 0
Jan 31, 2007 | 09:08 PM
i also wondered about gf210's for the coupe..found out that they only make them for the sedans
Reply 0
Jan 31, 2007 | 09:13 PM
I'm probably gonna try the GF210's...the 350Z series fit the G.
I do canyon runs and hit the track about 3 times a year so maybe better handling is the best choice.
We shall see...decisions...decisions...
Reply 0
Jan 31, 2007 | 09:16 PM
Quote: considering I have to angle out of all driveways now with only 350z-htechs, I would say plan on angling over everything from now on
Damn...now that i see your forum name... makes me miss my '98 EGP Prelude...
Reply 0
Jan 31, 2007 | 09:20 PM
if you want performing springs, look into swift
Reply 0
Jan 31, 2007 | 09:57 PM
Just did. I am going w/Swift's!
I'm not looking into having the car slammed...I want a bit lower but want to gain performance
Damn...the G35 Application for they are softer spring rates...
So based on the sticky re: springs...
The 350Z application will give me a 1.3 F and 1.1 R?
Will the spring rates remain same or will there be a slight diff?
Reply 0
Feb 1, 2007 | 12:30 PM
You may want to consider the Swifts, I just got a set for my friends G coupe, he loves it. You can read about it here http://www.mynismo.com/products/?id=5957
Reply 0
Feb 1, 2007 | 12:56 PM
The 350Z application or the G35 application?
Reply 0
Feb 1, 2007 | 01:35 PM
Quote: The 350Z application or the G35 application?
If you want stiffer spring rates and lower ride height than sure, go for it.
Reply 0
Feb 1, 2007 | 01:48 PM
Quote: If you want stiffer spring rates and lower ride height than sure, go for it.
Which application did your friend go w/is the question.
Reply 0
