03' G35 Coupe factory 18" wheel Spec?
Old Feb 20, 2007 | 09:31 AM
edwinhui's Avatar
Hi everyone..
Just want to know what is the spec for the 03' G35 Coupe factory 18" wheel front and the rear?
Are they(all four) all same?
Please help me guys!
Thank you!
Old Feb 20, 2007 | 12:14 PM
Calvin's Avatar
Overglorified Altima
a simple search would have yielded the answer for you:
18" 7 spoke (2003/2004 optional 2005+ Coupe std)
Front & Rear: 18"x8" +30mm offset
so to answer your question, yes - they are all the same (i.e. they are not staggered).
Old Feb 20, 2007 | 05:17 PM
Tunerz_Store's Avatar
weight=25lbs w/o tire.
Old Feb 20, 2007 | 05:48 PM
Callaway's Avatar
So it's just the tires that are different? All four stock 18" rims are the same size?
Old Feb 20, 2007 | 07:26 PM
yes. although the part numbers are different at infiniti.
Old Feb 20, 2007 | 08:17 PM
Callaway's Avatar
OK. So when buying aftermarket 19" rims, I don't really have to worry about two different rim sizes, just make sure the tires are staggered.
Old Feb 20, 2007 | 08:18 PM
you can do either that you wish. most run staggered aftermarket wheels or you could run same size wheels and stagger the tires.
Old Feb 21, 2007 | 05:24 AM
edwinhui's Avatar
Thank you all very much!
Heres what happened to my G.Coupe, I got some new tires(F-245/40 R-255/45)for it from the DiscountTire,
they put one of the rear wheel to the front(with the 245 tire), and put the one from the front to the rear(with the 255 tire).
At that time I can tell by the brake dust on the wheel, sure I asked them and told them about it, but then they told me the wheels are the same on the car.
so I just want to make sure its ok for the safety!
What do you all think?
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Soumilg
Jul 18, 2015 12:33 PM
