Non-Brembo to OEM Brembo upgrade & Stiffener question
I spent over an hour using the search function with no luc.
I just won a 350z Track Brembo setup on ebay with just calipers and rotors. What other parts will I need to complete the upgrade? Will my lines fit? I was planning on getting SS lines anyway so do I need to order specific ones for the Coupe Brembo or are they the same?
Does anyone have a brake stiffener? Does it really work? I was thinking of getting the Stillen. Any thoughts?
I have an '04 Sedan, Thanks.
Originally Posted by Nismo G
Does it come with the mounting brackets? Im pretty sure you will need new ones. As for a brake stiffener..i have never heard of one. I have heard of the master brake cylinder made by stillen if thats what your refering to...? Yes it will work.
-sean
-sean
-sean
-sean
Thanks
Originally Posted by silvernole12
I have done the swap on my car. You will need the caliper mounting bolts for the rear calipers. If the lines didn't come with the calipers, then you will need the brembo lines or just get SS lines. The goodridge lines I bought were for both the brembo/non brembo coupes.
Thanks for the feedback.
$1400 + $90 to ship. less than 5K on the rears about $13K on the fronts. So fairly good I guess. The stiffener is for the master cylinder, it supposedly moves when you press the pedal, so you loose braking power.
Now all I need to find out is if it'll fit my wheels and if I need a new spare or not.
Originally Posted by 04NismoV35
Just bolts, no brackets? How about the front direct bolt-on swap? How do you like the brakes? Do they feel much better?
yep just the bolts. Front should be direct bolt on. I actually bought front bolts just in case, but they say the stock ones fit. They feel better but not sure if thats because of the stainless lines or the new calipers since it was all done at once.
Ok, I have the OEM Brembo brake setup in my possesion now, but I still have a couple of questions.
1. Will the sedan stock sport 17" wheels fit these calipers or do I need spacers?
2. Will my spare fit or does the coupe have a different spare?
3. Where can I find Goodridge lines at a good price, the cheapest I see is Racing Brake @ $244, seems expensive.
So what do you guys think?
Thanks
Update: The shop doing the brakes said that the StopTech kit said those aren't actually compatible and that some of the kits out there have the potential of sliding off if they are not the right kit as shown in the pic on Stillen's site. I have no idea what he's talking about, do any of you?
Ok now I'm 4, 6 & 8 line kits so I'm really confused.
Thanks
No. No OE sedan wheels clear the front Brembo. Rears clear.
No. The OE spare does not clear. If I remember correctly the coupe donut did not clear as well.
Buy Stoptechs or check out performancenissanparts.com.
Thanks
Thanks
I did the swap and switched back to the sedan brakes when I tried to fit my wheels. Thankfully, I removed the dust shield and not simply cut it.
Thanks for feedback.
