Has anyone come across this strut bar before?
Old Apr 16, 2007 | 09:46 AM
  #196
05Scoobyroo's Avatar
FilaNJ, where in jersey are you? I had no issue installing mine, I don't mind helpin, where you at?
Old Apr 16, 2007 | 10:46 AM
  #197
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Which bolt is it? I had to tighten the bolts in a specific order, otherwise, the passenger frontmost nut won't go on. The rearmost passenger one had to be tightened to press the bar down enough to let the last one get started.
Old Apr 23, 2007 | 03:53 PM
  #198
Sidewy8's Avatar
Originally Posted by filanj
It was the rearmost passenger one. I would have needed someone to stand on the freaking bar while I put the nut on in order to get it to catch. At this point I stripped the top of the bolt, so there is no way to get it to bite now. If it the very top (which is the only part.. the first couple threads) wasn't worn, than it would have worked once I figured out the order.
I'm having the same problem with mine. I can only get the outside and front bolts on. The rear bolts on both sides are too short -->> The plate is not sitting flush so I can't get the nut to bite the bolt. Damn!!
Since these bars are a solid one piece, manufacturing have to be perfect. I guess my wasn't. I dont' know if Phase2 will exchange it for me. Anyone??
Old May 10, 2007 | 06:14 PM
  #199
nfo184's Avatar
would the bars get mixed up between the 350z and the g35 bar?
Old May 10, 2007 | 06:57 PM
  #200
Calvin's Avatar
Overglorified Altima
lots of vendors often assume all 350z parts fit the g35 as well. this, however, is in fact for the g35.
Old May 11, 2007 | 11:50 PM
  #201
Triji's Avatar
This fit great on mine... The only issue I had was removing the bolts to begin with. They were over TQ'd and I stripped a cpl of em... I replaced the bolts before installing the bar. That might be the answer, just buy replacement bolts from the dealer before you attempt the installation.
Old May 17, 2007 | 07:09 PM
  #202
nfo184's Avatar
wow i love that blue.....yea i just ordered mine so hopefully its meant for the g35 and also fits
Old May 17, 2007 | 07:33 PM
  #203
Mr.GEE's Avatar
20 Year Member
I ordered one about a month and a half ago and every time I check the status of my order, it says "This order is on hold". I think they are out of stock. I called them two weeks ago and they said they didn't know when they get the next shipment. I'm tempted to just cancel the order and buy the Ritchie bar. Anyone else run into the same problem?
Old May 18, 2007 | 01:16 PM
  #204
NETSHARK's Avatar
Just ordered it the day before yesterday, and yesterday they shipped it !!? Come on they are so quick !!, just call them i`m sure there is another problem ?
Old May 18, 2007 | 02:00 PM
  #205
b00stedjustin's Avatar
on the circuitsports website there is a carbon fiber bar for the Z. anyone know if they have one for the G?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
