springs
Old Mar 18, 2007 | 03:59 PM
Leo350GT's Avatar
springs
hey guys..im in the look for some springs..whats a good brand for my G-coupe and how low should i lower the car..thanks in advance.
Old Mar 18, 2007 | 05:13 PM
G STACKS's Avatar
i prefer Tein H springs or Tein S springs for a more lower drop
just type in search there are TONS of threads about this
Old Mar 18, 2007 | 05:15 PM
Calvin's Avatar
Overglorified Altima
how low should you lower it? that depends on what you want...
do you want it to look good, but not be able to drive anywhere?
do you want it to be comfortable, or do you like stiff rides?
do you like the slammed look or subtle look?
do you want to deal with camber issues and have to buy camber kits?
what size wheels/tires do you have? offsets? are you okay with rolling the rear fenders?
you're being way to broad with your question. be more specific and we'll help you as best as we can.
Old Mar 18, 2007 | 05:58 PM
Leo350GT's Avatar
yooo
thanks
Old Mar 18, 2007 | 06:00 PM
Leo350GT's Avatar
im looking into getting 20x10.5 in the rear and 19x10 in the front.. i want it give me a good tuck look to my G..but that also gives me good performance as well..thank u guys for ur patiences i have been learning everything about my car through you guys....thanks
Old Mar 18, 2007 | 09:54 PM
Calvin's Avatar
so you want the tires to be tucked behind the fender? that's going to involve a very aggressive drop in which you'll probably want to buy front/rear camber correction kits - unless you've got the money to buy new tires every other week also, depending on your offsets and tire sizes, the chances are you are going to rub with a slammed car and 10"/10.5" wheels. your options are to roll/shave the fenders or run an aggressive camber to avoid rubbing. the problem with running an aggressive camber is uneven tire wear.
what is your budget? if money isn't too much of an issue, i'd definitely opt for coilovers so you can adjust the height to your perfect drop and possibly adjust the ride stiffness (depending on which coils you get).
be aware that loweing the car (properly) is not cheap.
Old Mar 18, 2007 | 11:30 PM
BadBoy06's Avatar
search some H-techs or S-Techs or Eibach Pro Kit..plenty of pics
and wheel sizes to go through.
Sounds like you dont want to spend crazy $$$$ since you only mentioned
springs as the drop method.
At least you will have a feel with those ^^^^ springs.
Maybe look here for added info
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
Old Mar 19, 2007 | 07:49 AM
Leo350GT's Avatar
thanks for the info guys
Old Mar 19, 2007 | 07:50 AM
Leo350GT's Avatar
yo yo
will probably do coil overs instead
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
