kw variant v3 coils
Old Apr 16, 2007 | 05:20 PM
wongdood's Avatar
kw variant v3 coils
does anyone have any experience with these? I read the stick with the specs and was just wondering what i should get.
other ones on my list are
cusco zero2
bilstein pss9
and hks LS
Old Apr 16, 2007 | 05:56 PM
helldorado's Avatar
Give me about 2 weeks. Ordered a set last Friday. Will be installing them with 350EVO sway bars and SPL end links.
Old Apr 18, 2007 | 03:00 PM
wongdood's Avatar
sounds good, i'm looking into buying these
Old Apr 21, 2007 | 09:19 PM
jbone's Avatar
'04.5 Black 6MT Coupe
a bud of mine put them on his s2000...absolutly loved them, even on that car. I'd like to hear the buz on these coils for our car,too.
Old Apr 21, 2007 | 10:14 PM
nghiars's Avatar
^^^hilarious avatar
Old Apr 21, 2007 | 10:40 PM
scott1026's Avatar
i have it in my 03 coupe, handles well, rides pretty much like stock (i did a LOT of research when i comes to buying coilovers, i wanted sporty handling without sacrificing ride comfort), and take hard corners really well, i'll give it 9 out of 10, only downside it's kinda pricy...but then again, you get what u paid for. I stronly recommend it.
Old Apr 22, 2007 | 07:40 AM
slimjim's Avatar
how easy are the adjustments?
Old Apr 23, 2007 | 03:07 AM
scott1026's Avatar
Smile
well, it's my first coilover, but nevertheless I'd consider it pretty easy to adjust height and stiffness.
Old Dec 3, 2007 | 11:45 PM
sansin's Avatar
i realize this thread was started a while ago, but i have been searching and have not found many reviews re: the kw's. anybody have any input??? i've been thinking about getting the v2's. i hear that they run slightly stiffer than stock, and are good for those looking for improved handling, but not something for the serious auto-x-er/road-racer.
i'm also hoping to see what these look like completely dumped. i know a lot of bmw guys use these, and can get their rides pretty low. i also read somewhere that they can lower the G 1.5" all around.. comparing to df210's (1.7f, 1.3r) that seems like what i'm looking for, but was just hoping someone had a pic.
tia,
dave
Old Jan 17, 2008 | 11:02 PM
fbw5595's Avatar
I think the smallest drop allowed by the KWs is 1.8 all around. I too would like to see a picture and hear other reviews.
Old Jan 18, 2008 | 07:13 PM
mforrest100's Avatar
You guys should search in the my350z.com suspension forum. They have reviews over there.
Old Jan 18, 2008 | 07:19 PM
sansin's Avatar
thanks guys. i actually bit the bullet and got some v2's... i am truly impressed.
ride comfort is spot on with just the recommended settings. there is a firm/confident quality about them, but nothing harsh at all. i fell like i'm gliding over everything, but when i bear into a turn they stiffen and give methe response i need. and i'm actually closer to 2 inches... with room to go more. def. worth the money.
edit:
and if you do decide; hit up eddie at THMotosports. great guy to work with and he'll get you the best deal around
Old Jan 18, 2008 | 09:14 PM
fbw5595's Avatar
Do you have a picture of your car with the V2s? What setup are you running? Do you rub? Is a 2 inch drop the smallest drop allowed?
Thanks.
Old Jan 19, 2008 | 06:23 PM
sansin's Avatar
sorry no pics yet... and it's winter here, so running stockers right now... def. no rubbing issues. i am tucking all tires though, so my 20x9.5 20x10.5 iForged setup would def. rub. this summer i will have to roll fenders before putting the aftermarkets on.
there is someone else on the forum that had v2's.... he had pics up (i was searching for you but couldn't find them again). if worse comes to worse, i'll snap some later and post them up.
edit: re: the 2" drop... not really sure. i didn't see how far down i could go. but they setup is actually for a 350z.... i believe kw only makes them for the z, but since they fit both cars... drop stats for the Z are 1.5 all around. add the extra 0.5 inch since this is a G.
the guys that did the install said they would go a little more than 0.5 lower in the front and even out the rear... this is compared to the s-tech i had on previously... so roughly 1.75 (a little more than that though) all around. and he said there's still room to go
Old Jan 19, 2008 | 07:23 PM
fbw5595's Avatar
Okay, thanks. I will look for that picture.
I am more interested in the least amount of drop, highest ride height. I am not really a fan of the dumpped or slammed look.
