Sagging
Old May 4, 2007 | 09:35 AM
redriderr's Avatar
Sagging
When i walked out to my car it looked like the driver side rear was a little lower than the passenger side...I measured it and it is less than a quarter inch lower. It's an 03 Coupe with 71k on it. Do I need new springs? Is it even that big of a deal?
Old May 5, 2007 | 12:27 AM
g35philong's Avatar
Is your car lowered by chance? Check your other 3 springs to see why that only one side is sagging, you may need new springs, make sure your shocks are in good condition. If not I'd take it to a shop to find out what is that problem.
Old May 5, 2007 | 02:50 AM
ttrank's Avatar
Grocery getter
1/4" is not much. Are you 100% sure is was on level ground.
Old May 7, 2007 | 09:36 PM
redriderr's Avatar
Yes it was on level ground...I moved it to level ground just to make sure. Worse case scenario I'm hoping all I need is springs. But then that draws the question as to which ones to get. There are soo many options and everyone has their favorites...
Old May 10, 2007 | 05:01 PM
redriderr's Avatar
FAAWWKK! I'm out riding around and I hear a squeaking noise...once i stop the car, I open the door and push on the rear and it squeaks. I guess its time to change out the supsension. Is it just the springs? or do I need new shocks? or both? I have a nissan warranty on the vehicle that expires at 84k miles. I'm hoping they cover this. Keep in mind that I've only had the car for 10k miles!!!!!
vstring
Sep 21, 2015 11:14 AM
itschuckster
Jul 25, 2015 08:07 AM
Devil Dog
Sep 2, 2009 10:09 PM
ORANGEBSRT
Aug 10, 2007 12:57 PM
