View Poll Results: What is the best coilover system for under $1100?
Tanabe Sustec SOC2
7.41%
Tein Basics
31
57.41%
Ksport Kontrol Pro
3.70%
Blitz TR-1
1.85%
Just get Tokico D-Spec Shocks and a Good Spring
18.52%
I know another kit you can get that is better than those for under $1100
11.11%
Voters: 54. You may not vote on this poll
Which coilover system for under $1100 ?
Old May 10, 2007 | 03:02 PM
  #31
Skaterbasist's Avatar
Retired SuperMod
I've seen that thread 100 times.
As far as what im sticking too, ill be getting some stillen sways and installing it myself. Unless I find an installer who does it for a spectacular price, which I doubt.
As far as coilovers, im going with Tein Basics. Im debating whether Its worth installing it myself though.
Old May 10, 2007 | 03:32 PM
  #32
Concealed StrateG35's Avatar
Did you purchase your Tein Basics already?? I'm going to buy some soon let me know if you are ready to pay to see if we can get a lower price on them! PM ME!
Old May 10, 2007 | 03:45 PM
  #33
bc= bor chuan racing...they manufacture megans coilovers...apexi's and many others...
bc racing BR series... 53mm shocks, pillowball mounts, 30 way adjustable, 1 year warranty...after the 1 year $95 gets you a new coilover if they blow out!
They are on the level of tein flex etc... 929 shipped in stock
What do you guys think about this? ANyone has them?? ANy experience, comments? I've looked around and no one seems to have them
Old May 10, 2007 | 03:56 PM
  #34
Calvin's Avatar
Overglorified Altima
come down to sd for a good price on your coilover install.
Old May 10, 2007 | 04:20 PM
  #35
MechEE's Avatar
Originally Posted by izmir41500
it's easy if you have the right tools. i couldnt break the bolts loose
but i had everything else.
have you seen this thread: https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
there's a ton of info in there.
I was thinkin about the stance then I read:
Stance coilovers (Monotube, true coilover in rear, 15 way adjustable dampning, full height adjustable
Spring rates 672/280*
*since rear springs are run on coilover body, they leverage more spring power to the rear wheel. To get the same spring power to the rear wheel as a 280lbs spring in the OEM location you would have to use a 448lbs spring.
CAUTION: Really good owner review's exist and at $1150 shipped they are a excellent value. But a number of owner's are experiencing issues with the lower shock mount bushing not being designed to carry the loads being asked of it since the oem setup was not designed to have the springs with the shocks. A new sperical bushing fix has been talked about, but hasn't been produced yet. One could alway's convert to a 448lbs spring setup in the oem location and avoid the whole issue.
I had similar concerns, which is why I went with their OEM-style version instead of the spring-on-shock configuration. They discontinued this version due to lack of demand (most people go for the original coilover rear style), but it can be special ordered.
Old May 10, 2007 | 04:23 PM
  #36
Retired SuperMod
Free?
Old May 10, 2007 | 04:32 PM
  #37
how much does it normally cost to install coilovers ?
Old May 10, 2007 | 07:27 PM
  #38
Retired SuperMod
Anywhere from 150 to as much as 300. It varies depending on how much an hour they charge, and how fast, or slow they do it.
Old May 10, 2007 | 08:19 PM
  #39
I ordered some Tein BASICS!! $749.99 SHIPPED!! yay!
Old May 10, 2007 | 08:26 PM
  #40
Retired SuperMod
I feel left out
Old May 10, 2007 | 08:33 PM
  #41
Calvin's Avatar
VERY few shops will charge 150 to install coilovers. hell, most shops charge 150-225 just for springs! avg is 175...
i'd expect to pay anywhere from 250-350 for coilovers. but come to sd and you'll get a deal.
Old May 10, 2007 | 08:47 PM
  #42
The gas that I will spend on driving down there and back alone will be like $300 haha
Old May 10, 2007 | 08:50 PM
  #43
Calvin's Avatar
not you! skaterbasist!
Old May 10, 2007 | 08:52 PM
  #44
redlude97's Avatar
Call worldone for a quote, they do alot of the stuff for the z/g guys around here, and should charge a reasonable price.
  #45
hahaha i was about to say, maaan that would be the story of the year " I travelled 1500 miles to get a "hooked up" deal on the install of my coilovers" haha
