does anyone make a spring rate as stiff as a stock 05 coupe w 19s?
Old May 15, 2007 | 08:07 PM
Boostwhore's Avatar
Does anyone make a comparble spring rate to a 05 coupe with the factory 19s... im under the impression that the stock springs are linear from what ive read? I always thought factory springs were progressive... I cant find anything thats comparable and gives about an inch drop. htechs are to soft and the s techs are not linear up front...
Old May 17, 2007 | 08:31 AM
dovla's Avatar
Nissan does, with revised 350Z (2005+) springs. Or mix H-tech for Z on front and OEM Z springs in rear.
2005 OEM 350Z: 314 / 427
H-tech: 358 / 375
Or go with Basics: 500 / 500
Old May 17, 2007 | 09:29 AM
redlude97's Avatar
H-tech: 358 / 375
that will not get him a 1" drop tho, really the only options are coilovers such as the Tein Basics, most springs were designed for the nonsport suspension back in 03, so none are stiffer than the sport suspension with the exception of the nismo t2 linear springs, but those are way to stiff for any stock shock/regular upgrade, and should only be used with revalved konis.
Old May 17, 2007 | 09:38 AM
b00stedjustin's Avatar
1 you don't want linear spings period unless you are going with a full coilover setup. If you are just getting new springs you want them to have a progressive spring rate. Also I don't think our stock G's have linear spring rates.
Old May 17, 2007 | 09:55 AM
redlude97's Avatar
why wouldn't you want linear springrates? and what makes you think oem springs are nonlinear when all the evidence points towards it?
edit: these look linear to me...
Old May 17, 2007 | 10:20 AM
dovla's Avatar
OEM Z springs lowered me 27/24 mm in front and 12/12 mm in rear.
H-tech for Z lowered me 32/31 mm in front.
Old May 17, 2007 | 01:28 PM
trey.hutcheson's Avatar
The OEM springs are linear. And I don't see how any one that flogs his car would want progressive springs.
TWASkyliner
Feb 8, 2020 08:00 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Karnicle
Jul 23, 2015 05:08 AM
