G35 Compression Rods are Total Crap
#77
![Angry](https://g35driver.com/forums/images/icons/icon8.gif)
Originally Posted by bocatrip
I have a 04 Coupe with 22,000 miles and my girlfriend's 06 sedan has 14,000 miles. Both cars have creaking coming from the front end which can be heard going up and off driveways. I've just noticed my creaking and I have 2 months left on the warranty. The compression rod is over $300 for the part alone and the noise usually develops after 20,000 miles. I never have my radio on so I hear everything. I had a G35 loaner that had more creaking than I could handle in the few days of driving. Again, we have another annoyance and expense on a car that is supposed to be reliable. I have tolerated the weak paint, brake dust and premature pad wear, rattles, distorted front end geometry causing inside front tire feathering as well as premature middle tread wear on rear tires, and now creaking from the compression rods that makes the car sound like an old beater. There have been numerous threads about the bushings on the compression rods, but when a 14,000 mile 06 sedan has the same issues I feel that this is all getting very old.
![Confused2](https://g35driver.com/forums/images/smilies/confused2.gif)
![Icon43](https://g35driver.com/forums/images/smilies/icon43.gif)
![Mad](https://g35driver.com/forums/images/smilies/mad.gif)
Front Compression Rod Part numbers:
54468-AC70F
54469-AC70F
I'll be looking elsewhere when time to buy another car. I wouldn't buy another nissan/infiniti ever again.
#78
Originally Posted by jomjalee
I'm on the same boat. I have a 05 6MT Sport with same problems you've listed it above, plus my engine burns oil
, which they refused to cover it under warranty
. I just got my front compression rods replaced under warranty. I'm so disappointed with Nissan/Infiniti products (I had a 240SX). Too many problems for a $35K car.
54468-AC70F
54469-AC70F
54468-AC70F
54469-AC70F
#82
on
Well I removed the nut securing the compression rod to the frame but was unable to remove the nut on the "knuckle" side. The bolt would just spin. I applied PB on it and tried, sprayed and tried again. I'm done. This car is one nuisance after another. I was willing to do the swap even though there is no guarantee that this is indeed the cause of the clunking. My dealer wants $1000 (parts and labor) to do this. Again this may or may not eliminate the clunk. I have learned to hate this car. I'll begin removing the parts I can and trade this in (or maybe wait to cool off and pay the money to repair it -
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
#84
on
Still there
The dealer replaced the rods today and called to say that another noise is heard. I beleive they are hearing the same noise as before. The best guess is that the knuckle ball joints are bad due to me having the coupe springs. I seariosuly doubt that the coupe springs are the culprit.
I have 73,000 miles and aside from the front suspension clunking (compression rods replaced at 48,000 and 73,000- to no avail) and the tire wear that the 350Evo arms corrected the car has been fine. But do I keep the car and plop another $1,000 into the knuckle replacement on top of the $1,000 for the comrpession rods replacement cost performed today? I just don't know!
![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
#85
I replaced my compression rods yesterday while installing the Tein Basics and SPC Camber arms. Jason at Riverside supplied the new rods and a local shop charged me $360 to install the Teins, Camber Arms, compression rods and new end links front and rear. No more squeaks, clunks or any other noise that was pissing me off. The car is tight and aligned within spec.
redguitarfreak (10-24-2013)
#86
on
I had attempted to remove the rods but the bolt would spin when removing the nut. I had Motorwerks in Barrington replace the rods (though I bought the rods through Jason as well). I wish my car was tight. For me to trade this thing in requires that I take a beating on the depreciation. KBB lists it at approximately $15,000 - I paid $35,000. Each mile has cost 27.4 cents in depreciation alone. I hate having to drive so much!
#87
#88
on
Originally Posted by Dan_K
What kind of noise to bad compression rods specifically make?
#89
on
my compression rod was making one hell of a noise awhile back..a creaking noise but fairly noticable.... i fixed mine by hitting the bolt with my 1/2 impact gun(basicly putting more torque on the bolt(tighter))...havnt had the noise come back yet(and this was 5 or so months ago)...... but in my case it was not a light sound as mentioned in the post before...but did happen quite a bit.... but in any case before you go out spending more money try and tighten the bolt ...makes sense if the bushings are not visable damanged and u replaced the rod already..maybe it just came loose a little after however many miles...anyways its worth a shot, only takes a few seconds to tighten it some more
sorry if someone mentioned this idea.... i skipped a few pages
#90
What kind of noise to bad compression rods specifically make? I had no noise until I installed some coilovers. Now on bumps over uneven roads I get a sqeaking on the driver side when the car goes up and down.
