SPC Rear Camber / Toe Kit
Old Jul 25, 2007 | 02:13 AM
WTF??'s Avatar
Hey guys, I got the SPC/Eibach Rear camber kit installed. The alignment tech had a little issue with the washer on the toe bolt. I remember reading up the some people had to elongate the hole for the toe bolt? Can those who did this, elborate on why this needs to be done. Pics would also help. Did anyone else have problems with the washer?
Because of this issue, my rear camber is stuck at -1.9 to -2.0 degrees... which still isnt bad
Old Jul 25, 2007 | 02:14 AM
Calvin's Avatar
Overglorified Altima
if you dont elongate the hole, you can't really adjust the toe..
Old Jul 25, 2007 | 02:17 AM
WTF??'s Avatar
^can you elaborate on how to elongate it? vertical? horizontal? what tools?
The toe was able to be adjusted, but would only allow -2.0 degrees on the camber. If the camber was adjusted anymore in the positive range, the toe became off again... this is all because camber affects toe, and vise versa...
Old Jul 25, 2007 | 02:19 AM
Calvin's Avatar
the spc/eibach kit should have come with a template to use. you'd use a dremel.
Old Jul 25, 2007 | 02:22 AM
WTF??'s Avatar
^crap... if there was a template, I dont think I have it anymore... any other possibilities?
thanks for the quick response Hero! again youre the guy with many answers lol
Old Jul 25, 2007 | 02:34 AM
Dan_K's Avatar
Should help: http://turboneticsownersclub.com/tur...oltinstall.pdf
Old Jul 26, 2007 | 12:37 AM
WTF??'s Avatar
^That definitely helps!!
Thanks a mil
Old Jul 26, 2007 | 12:16 PM
lekker_droom's Avatar
Ok so is this an issue that needs to be addressed on the newly released redesigned SPC kits?
Old Jul 26, 2007 | 12:32 PM
redlude97's Avatar
The rear kit was never redesigned, and elongating the holes was always required
Old Jul 26, 2007 | 01:02 PM
Calvin's Avatar
you're thinking of the front kits. the OP is talking about the rear toe bolts.
Old Jul 26, 2007 | 02:12 PM
Well im getting front and rear kits installed this weekend, just put them in my sig a little early.
Anything i need to be aware of then? These are the newly designed kits I have front and rear both with new part numbers.
lemme know, thanks.
Old Jul 26, 2007 | 03:31 PM
Calvin's Avatar
if you're slammed, then you might still knock with the spc arms (i know i did, so i raised it). the spacers are necessary to get back into spec for aggressive drops.
Old Jul 26, 2007 | 05:13 PM
ok cool, dont plan on dropping it much, highest setting which I believe is an inch drop.
Old Jul 27, 2007 | 10:57 PM
WTF??'s Avatar
Anyone want to pass me on your template after youre done????
Awwww.... why not???????
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
