Tokico D-Spec vs. Tein Basic
Aug 15, 2007 | 12:06 AM
I was talking to a service manager at Stillen about getting the Tein basics, but he said I could achieve the same performance level if I go with the D-Spec (http://www.stillen.com/product.asp?i...odel=G35%204DR) for 2/3 the price. Besides he said the Tein basics will be pretty noisy. What do you think? How much will the drop be for the D-Spec?
Reply 0
Aug 15, 2007 | 12:15 AM
what springs are you planning on using with the tokico d specs? the tokico's are only shocks whereas the tein basics are coilovers which are integrated spring/shock. the basics are height adjustable only and the dampening is preset. the tokico's won't lower anything...that will be determined by which spring you're using.
Reply 0
Aug 15, 2007 | 12:18 AM
If you want more control, go with the D-specs. If you want a very good matched system that has height adjustment go with the Tein.
Reply 0
Aug 15, 2007 | 12:41 AM
Quote: what springs are you planning on using with the tokico d specs? the tokico's are only shocks whereas the tein basics are coilovers which are integrated spring/shock. the basics are height adjustable only and the dampening is preset. the tokico's won't lower anything...that will be determined by which spring you're using.
I think the D-Spec also comes with the springs. It's a spring/shock combo I think.
Reply 0
Aug 15, 2007 | 12:44 AM
Quote: If you want more control, go with the D-specs. If you want a very good matched system that has height adjustment go with the Tein.
I don't mind the extra cost of the Tein basics, but from what I heard, the noise is one of the reason I don't want to go with the coilovers.
Reply 0
Aug 15, 2007 | 12:46 AM
Quote: I think the D-Spec also comes with the springs. It's a spring/shock combo I think.
if you look at that link you posted, it states "shocks only"
Reply 0
Quote: I don't mind the extra cost of the Tein basics, but from what I heard, the noise is one of the reason I don't want to go with the coilovers.
basics aren't that much more....they are around $800. the tokico's are less but you'd have to buy springs.
Reply 0
Aug 15, 2007 | 12:55 AM
Quote: if you look at that link you posted, it states "shocks only"
I guess you're right.
Reply 0
Aug 16, 2007 | 02:55 PM
what noise?
Reply 0
