Explain the basics of Coilovers / shocks / springs
Old Sep 2, 2007 | 04:06 AM
johnsonhuang's Avatar
So im a total noob when it comes to suspension.
from what im aware of, Coilovers = shocks + spring + dampers?
so if i got some tokico shocks, s-techs, and some dampeners, would that make me have a coilover kit? correct me if im wrong.
please inform? planning to lower my car some more! =)
Old Sep 2, 2007 | 11:27 PM
SCoupe's Avatar
Coilovers - @ least on the rear - are complete 'units' with springs installed over struts similar to what you have on the front. With a rear coilover you lose the separate spring which you now have. That's the quick & dirty description anyways.
Old Sep 10, 2007 | 02:17 AM
Goonar's Avatar
Geee Man
bump...im curious as well for more info as I know NOTHING about lowering my car.
Old Sep 10, 2007 | 11:10 AM
LudwigB's Avatar
try this:
https://g35driver.com/forums/brakes-suspension/176880-excellent-tutorial-introduction-coilovers.html
Old Sep 10, 2007 | 11:42 AM
izmir41500's Avatar
G35driver Addict
Originally Posted by LudwigB
link to the link you posted:
http://www.my350z.com/forum/showthre...hlight=tein+cs
Old Sep 10, 2007 | 12:03 PM
gqong's Avatar
coilovers give you the ability to adjust ride height..for the rear it is the same as a strut+spring setup...not as someone mentioned above. you put springs in and as well as replace the strut. the spring can be adjusted to drop the height.
if you get tokicos + springs you can not do adjust height. but you will go lower.
EasySausage
Sep 24, 2015 01:06 PM
TheBay
Sep 3, 2015 03:27 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
si_driver
Aug 11, 2015 07:08 AM
