alignment was -4.3!!
Old Sep 9, 2007 | 06:42 AM
lawrencexchu's Avatar
i went to the a body shop today to install my camber kit and they tried to fix my alignment and orignially it came out to be -4.1 on the rear right and -4.3 on the left! . they aligned it to about 2.5 and 2.7 but it is still off and fixing it more would supposably make my tires rub on the fenders.
is there something wrong with the car? i didnt think that lower on eibach spring would put my alignment so negative and they also said that my rear isnt parallel to my front but not to the point where i have to worry about it.
anyone know the reason for this?
Old Sep 9, 2007 | 06:47 AM
g35rcr's Avatar
depends...eibachs can settle more than the advertised drop...what kind of alignment machine were they using and when was the last time they calibrated it
Fassster10's Avatar
ok who is they??? i suggest you take it to a place that specializies in lowered cars...
Old Sep 10, 2007 | 04:24 AM
hmm im not sure what kind of machine they use but i mean the angle to the tire tilted was pretty bad just by looking at it. the edge of the tire was even touching the floor.
Old Sep 10, 2007 | 04:26 AM
i mean "they" by the body shop. its called speed factory. its pretty nice there, realllly big, they have 7 lifts, alignment, a small store inside.
Old Sep 10, 2007 | 04:27 AM
does eibach have warrenty if the spring makes your car sag to low? cause the drop is moree then 1.7 inches
Old Sep 18, 2007 | 05:43 PM
G37Rider92649's Avatar
Hmmmmm What kind of camber are running, i have problems just like yours, but i have no camber, if i let go of my wheel it turns right for me hahahaha. I got SPC Revise cambers on the way though. Damn Gz
Old Sep 19, 2007 | 02:24 AM
redlude97's Avatar
was it -4.3 before or after they put on the rear camber arms?
Old Sep 22, 2007 | 12:28 PM
verbatim's Avatar
The G already has bad suspension, and you decide to install some Eibachs?
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
