car shakes when braking
Old Sep 10, 2007 | 07:21 PM
B~PAIN's Avatar
i have an 05 sedan mt with premium and everything ive got about 27k miles on the car and it started to shake pretty bad when i apply the brakes at high speeds is it time for some replacements or a check or something?
Old Sep 10, 2007 | 07:30 PM
Drewer's Avatar
Could be warped rotors, or shot bearing carriers.
Old Sep 10, 2007 | 07:35 PM
nghiars's Avatar
exactly what i was thinking..
Old Sep 10, 2007 | 07:37 PM
B~PAIN's Avatar
how could my rotors get warped wtf mate
where should i get this shizz fixed
Old Sep 11, 2007 | 02:37 AM
bigwilly's Avatar
Read this about warped rotors
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Then find a safe place and go a do a proper bed in of your brakes.
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
I had a used OEM Brembo kit from a 350Z installed a few weeks ago and was getting vibration at high speed braking. Did my 3rd bed in tonight and it is fine now, no more virbation. (The first two times I couldn't do the full bed in as I couldn't find a long and deserted enough stretch of road, but there was already a definate improvement after the 2nd attempt. )
Old Sep 11, 2007 | 06:52 AM
g35rcr's Avatar
if its warped just get them returned
Old Sep 11, 2007 | 09:20 PM
bigugly78cj5's Avatar
id just get your rotors turned.... if u have decent milage and or did a brake job recently it should be covered under the warranty(if u did it at a shop).....if not just get them turned if u dont need pads also... its most likely minimal warpage...if it was carriers id suspect more of a noise and or at all speeds to go along with the shaking...
Old Oct 28, 2007 | 05:13 PM
Da-G-SpoT's Avatar
I got the same problem in my coupe. When my brakes heat up it wobbles all over the place at low brake speed and high brake speeds.... I dont know what exactly i need done to my rotors as they only have 10,250 miles on them and original pads.... The dealer had changed the brakes and they left a pad without its placement pin on it and the pad was staying stuck on to the rotor making a noise when i turned. I fixed the pin situation that hled the pad in but didnt fix the rotors i guess, it still wobbles..... Any suggestions where i can get them resurfaced? I live in Miami Lakes, FL 33015
Old Oct 28, 2007 | 06:02 PM
g35rcr's Avatar
you can go to pepboys and have them do it if you take it off for 5 a rotor, some shots have an axle turning machine where you can leave the rotor on the car...check with your dealer
Old Oct 28, 2007 | 06:21 PM
gary c's Avatar
Warped Rotors........?
The issue here is warped rotors.........warranty! Infiniti/Nissan knows they
have poor quality rotors, they can turn them while still on the vehicle....
just use your warranty. This is caused by two things.....when the rotors
are manufactured they are not allowed to cool long enough and installing
wheels without using a tork wrench. Both of these contrubute to warped
rotors, next time you get new tires make sure your tire/wheel combo are
installed using a tork wrench!
Old Oct 28, 2007 | 06:52 PM
chilibowl's Avatar
Yes I believe I have this issue as well, and when I tightened my wheels, I tightened the hell out of them. I think the wheel tightened so tightly, put stress on my brake rotors and overtime warped em. I only have 18K miles and I get this same damn vibration at low speeds, its like a throbbing/tugging. Its annoying as hell but Ima bring it up to the dealership, hopefully I can luck out on a warranty, if not, ima take it to a local shop and either get them turned or resurfaced with new pads.
Old Oct 28, 2007 | 08:07 PM
Da-G-SpoT's Avatar
I usually tighten my wheels with an air gun which i have hooked up to my compressor... Is that too much torque? Its the same thing the guys at the wheel shop use so i hope that has been safe. Anyway, ill swing by Pepboys and resurface them and it go away. Doing a resurface means i have to change pads too? Mine are almost new and i dont want to waste my money. Thanks for the help
ghost_g35
Aug 7, 2015 10:31 AM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
mushu
Jul 15, 2015 03:55 PM
