Tokico HP Shocks
Old Sep 19, 2007 | 10:07 PM
The-Dream's Avatar
Tokico HP Shocks
I searched and only found information on the D-Specs. Anybody know anything about the Tokico HP Shocks? They're a lot cheaper than the D-Specs. The reason I want them is because I just bought some new springs and I heard the stock stucts and shocks would give out with aftermarket springs.
Old Sep 20, 2007 | 12:25 PM
Q45tech's Avatar
Tokico HP series is their version of a low cost oem replacement shock. They are usually roughly equal to oem in stiffness [maybe a little stiffer when brand new but decline as fast or faster than oem after 3-4 years].
Old Sep 20, 2007 | 05:59 PM
The-Dream's Avatar
What shock would you recommend that isn't too expensive? I'm looking more towards ride comfort.
Old Sep 20, 2007 | 06:00 PM
UnluckyCharms's Avatar
Zeals.
Old Sep 20, 2007 | 09:14 PM
The-Dream's Avatar
Originally Posted by UnluckyCharms
Zeals.
Any links? No luck with Google.
Old Sep 20, 2007 | 10:34 PM
superdds's Avatar
why not just go with the tokico d specs?
Old Sep 20, 2007 | 11:54 PM
The-Dream's Avatar
I wanted to find non-adjustable ones, as I wouldn't know what to do with them. Plus they are really expensive.
Old Sep 21, 2007 | 12:05 AM
superdds's Avatar
you ever consider going with tein basic coilovers? nothing to adjust...except for height. costs almost the same as tokico d specs.
Old Sep 21, 2007 | 12:13 AM
The-Dream's Avatar
I just ordered the H-Techs. How hard is it to fiddle with the D-Specs. Could I just tell the machanic I want a soft ride and that be the end of it?
Old Sep 21, 2007 | 12:20 AM
Yea, you could do that, but your *** might hurt if he doesn't use enough lube.
Old Sep 21, 2007 | 12:25 AM
superdds's Avatar
you can adjust d specs yourself. you will need to buy extensions for the rears and do a slight mod to access them from the rear deck. the fronts are easy to adjust. you just turn a **** on the strut tower.
Marlin84
Apr 1, 2020 12:52 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
TheBay
Sep 3, 2015 03:27 PM
