Suspension Question, Possible Camber Issues
Old Sep 27, 2007 | 12:25 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
I currently run 350Z H-Techs and I am replacing them with 350Z RS*R Ti2000. The drop with the H-techs did not require any camber adjustment parts front or rear as car was aligned back within specs. I have already purchased the SPC rear camber kit for the RS*R's. My question being with the H-Tech drop of .8F, .7R compared to RSR*R drop of 1.1F, 1.1R. Will this require a camber correction arm for the front with a 1.1 drop? Anyone with approx. a 1.1 drop in front please advise. I don't want to have to spend any money unless absolutely necessary. Thank you for your help.
File Type: pdf
Old Sep 27, 2007 | 04:38 PM
g35rcr's Avatar
it might not you might just barely be out of spec...what were you specs when you had it aligned last time?
Old Sep 28, 2007 | 08:10 AM
DRG35R's Avatar
20 Year Member
Bear with me as I have to dig those numbers out of storage. If it is close then I am not going to worry about it. How much of a difference could a .8F drop to 1.1 actually make?
Old Sep 28, 2007 | 09:35 AM
DRG35R's Avatar
20 Year Member
I know each car reacts differently, but I need others advice that have approx. 1.1F drop. Did you need to purchase adjustable camber arms for the front? Was your alignment way out of whack after drop or was it close to or within specs? I really need some help on this one as I want to have all the work done at once and I am waiting on whether to purchase adjustable front camber arms. Thanks for all of your help.
Old Oct 10, 2007 | 12:22 PM
DRG35R's Avatar
20 Year Member
anyone with 1.1 drop? I know you are out there. Can you share experience?
Old Oct 10, 2007 | 01:39 PM
redlude97's Avatar
so where are the old specs? I'm pretty sure your camber is going to be out in the front, its up to you to decide if purchasing a-arms is worth it
Old Oct 10, 2007 | 04:09 PM
Q45tech's Avatar
The rule of thumb is 1" drop ~= 0.83 degrees of added negative camber..extrapolate.
Old Oct 11, 2007 | 07:47 AM
DRG35R's Avatar
20 Year Member
finally got my old align specs after drop on 350Z H-Techs, will post later. I am not an expert at reading these things, but looks like I will need the front adjustable camber arms as I am just out of spec on the right front already.
Q45Tech, Thanks for the info.
Old Oct 14, 2007 | 06:52 PM
DRG35R's Avatar
20 Year Member
Alignment sheet attached to first post.
Old Oct 14, 2007 | 09:58 PM
redlude97's Avatar
seems like you are already out of spec for camber in the front, so any additional drop will put you out of spec even farther since camber isn't adjustable. Its up to you to decide if it is worth it to install camber arms. You will likely have some uneven tire wear depending on your driving
Old Oct 15, 2007 | 07:28 AM
DRG35R's Avatar
20 Year Member
yeah, the RS*R springs will definitely require camber correction. already decided to go with the 350Evo arms for help. thanks.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
beevanhuynh
Jul 23, 2015 01:37 AM
