To tein or not to tein
Old Nov 9, 2007 | 04:30 PM
blkonblk17's Avatar
Im looking to lower my car and wanted to know if this was actual. These numbers are specs ive gotten from researching from several sites etcs..
I have read that most people with g coupes used the 350z tein s tech because I believe of the better spring rate?
350z Tein S-Techs should lower the Z .7 F and .6 R with a 386/402 spring rate. So if you put those same springs on a G then you should get a 1.2 F with a .9 R drop right?
For a 350Z……… Tein S-techs
Design: F: Progressive R: Linear
F Drop: 17mm (.7in)
R Drop: 14mm (.6in)
For a G35 Coupe……… Tein S-Techs
358/274
F Drop: 26mm (1.2in)
R Drop: 23mm (0.9in)
Meaning the rear g35 s-tech spring rates are alot lower, is this why people go with the 350z s -techs, and if they do does it change the drop height from. .7/.6 to 1.2/.9 with better rear spring rate?
Old Nov 9, 2007 | 04:41 PM
tjlazer's Avatar
Yep, I just got a set of RS-R Down 350Z springs, great rates and .6 F & R (1.1" for G)
KruZZe
Feb 27, 2023 05:04 PM
nissandrifter32
Dec 22, 2015 04:28 PM
bigmike
Sep 17, 2015 01:58 PM
