The concise post on OEM 350z springs, pls help.
Old Jan 11, 2008 | 12:15 AM
netcbc's Avatar
Have searched a bunch but a whole bunch of mixed info, can I get some answers to the following.
1) Difference b/w revised and unrevised? (Is it just the year?)
2) How much drop for coupe on revised and unrevised?
3) Does a coupe need to replace shocks, struts or need camber if just swapping in OEM 350z springs?
4) I have a 2003 G35.C 6MT, which springs are best for my car?
Thanks a lot, sorry if it's a repost but I think this will help others with all the info in one place.
Old Jan 11, 2008 | 02:31 AM
Mr Inkredibul's Avatar
1) Learn to use the search function
2) Learn to use the search function
3) Learn to use the search function
4) Learn to use the search function
Old Jan 11, 2008 | 02:35 AM
Now because I know for some reason searching doesn't work that well:
1) They have different spring rates (Can be found in the sticky in the Suspension section)
2) .5 inch drop on both
3) No camber needed. If you go unrevised, no shocks needed. If you go revised, you need shocks to handle the higher spring rate
4) You want unrevised to match your stock spring rates.
More questions:
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
Old Jan 11, 2008 | 03:09 AM
HenryLee's Avatar
I actually have the revised 350z springs on my 06 g35c.. They give a noticable drop in the front but not soo much in the rear.. I would recommend getting tein 350z H Techs.. But 350z is nice if your looking for minimal drop..
Old Jan 11, 2008 | 11:56 AM
netcbc's Avatar
Thanks for the change of heart and answers, so revised and unrevised dont drop any more or less just different spring rate?
More questions:
https://g35driver.com/forums/showthread.php?t=65190
Old Jan 11, 2008 | 11:58 AM
netcbc's Avatar
I don't mind a minimal drop just want to keep same ride quality without spending on shocks/struts.
For 350z H Techs, do you need shocks/struts? Ride quality?
Old Jan 11, 2008 | 06:02 PM
Gilley's Avatar
This sticky tells you everything you want to know.
Old Jan 12, 2008 | 03:45 AM
netcbc's Avatar
saw that sticky but doesn't really answer my questions
For 350z H Techs, do you need new shocks/struts? Ride quality compared to OEM?
Old Jan 12, 2008 | 09:59 AM
Gilley's Avatar
That sticky tells you everything about spring rates and drops.
For the 350Z H-Techs, you don't need new shocks. However, you will notice a better ride with Tokoco D-Specs and adjustable swaybars.
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
