noise, vibration, harshness
Wilwood uses a billet aluminum caliper which is the lightest aftermarket caliper available. The only tradeoff is rigidity. It tends to flex slightly more than other "big brake kits." On this particular application (14" brake kit), the design of the caliper is improved vs. the standard 13" Superlite caliper. All in all, differences between 4 and 6 piston kits are minor, but Wilwood makes a great product and most people *think* 6 pistons are better than 4. The only negative comment I have in regards to Wilwood is that they do not have piston dust boots. So for everyday driving I do not feel their kits are suitable. However, on a caliper with these boots, they will burn off the first time you autocross a vehicle. Also, on my kit (13" superlite), the finish was less than desireable. They may have improved on this, however.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way), Hotchkis sways
just to answer some questions.
1. yes, they are from a group buy from brakezone
2. about $1800
3. noisy at first but now quiet as stock after 1 track day.
4. got the street pads
5. not anywhere as dusty as the stock pads
rob
03 G35C auto nav, alum. pedals, grounding kit, ultralight battery, Z tube (x), crawford plenum, RT cats, borla, ATI Procharger, CF Intake, J&S Boost/Knock, Wilwood brake kit
2. about $1800
rob
I really hate the brake dust from the stock brembo's... i'd consider upgrading to wilwood if it made that much of a difference...
Try a different pad (preferably ceramic). They have the least dust. I am not sure what is available for the brembos, but I'm sure someone here knows of a ceramic pad that will fit.
