03-04 Sedan lowered questions...
Old Jan 29, 2008 | 01:31 AM
TycoRC's Avatar
Infiniti G35 Sedan Nismo Aero Sport Package
So I've done a few research on this site, pretty new to the forum, and a proud owner of a Ivory Pearl Sport Tuned G Sedan on Nismo kit(Aero). Now I was handed down free 2006 Z shocks and springs and I installed it, its gave me a 1.5 inch drop but I was wondering, will it lower more if I put Coupe or Z lowering springs such as Tein S-techs Skunk2 or Espelier? I want to know if anyone has done such setup. I wanna clear the gap between the tire and the fender a little more. What lowering spring and shock set up are you sedans on? Would appreciate the help
This is how it sits as of right now on 06 Unrevised Z suspension(Shocks and Springs) only 9k on them and added 3k to them so far
Old Jan 29, 2008 | 01:56 AM
perry05G35's Avatar
Welcome the moderators will probably move your tread to the brake and suspension forum pretty soon. You will find the specs for all those springs that you mentioned on the first page of this sticky.
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
Most of use with springs have the Eibach Prokit or their sedan S-techs those that are lower than that have coilovers. There's really not too many guys that have the 350z/G35coupe secs of those springs. So don't expect too much feedback on them. Most will say get coilovers if you want to go lower than the 350z suspension you have now. They will run you about 800 for the tein basics. Which isn't bad considering what you are getting. Plus you will run into needing a camber kit if you don't want to deal with uneven tread wear.
Old Jan 29, 2008 | 01:59 AM
TycoRC's Avatar
Thanks
Old Jan 29, 2008 | 02:05 AM
TycoRC's Avatar
https://g35driver.com/forums/showthread.php?t=65190
Most of use with springs over coilovers have the Eibach Prokit or their sedan S-techs those that are lower than that have coilovers there's really not too many guys that have the 350z/G35coupe secs of those springs. So don't expect too much feedback on those. Most will say get coilovers which will run you about 800 for the tein basics.
As of right now its sits well, about a finger and half gap between the fender and the tire, I was just hoping to see what would happen if I ran coupe or z lowering springs, I dont want to of an aggressive drop
Old Jan 29, 2008 | 02:19 AM
perry05G35's Avatar
I have 350z/G35 coupe springs I wanted even drop both front and rear don't mind the extra gap since sometimes I do have to use the back seats. Even with your 350z springs you might want to get a camber kit front or rear depends on what your alignment specs look like when you get your alignment. I personally think OEM springs are the best choice for comfort and maintaining a close to stock feel in the ride. The S-Techs will give you a lower drop and they are pretty cheap.
Old Jan 29, 2008 | 12:03 PM
az1anbeethoven's Avatar
FYI, the 04.5 and up are revised shocks...your car looks pretty low on the 350z suspension on stock 17s...im kinda surprised....looks pretty good already!
Old Jan 29, 2008 | 02:21 PM
DaveB's Avatar
That is definitely not a OEM 350Z spring drop unless you have taller stock tires which it appears you don't. Your drop is about .75" lower than a 350Z spring drop so my guess is you've already got some sort of aftermarket spring on there. Be very aware that your drop is going to cause major tire wear issues, especially if you even go with wider than stock tires and rims.
Old Jan 29, 2008 | 02:26 PM
Klubbheads's Avatar
those are not z springs.
Old Jan 29, 2008 | 03:57 PM
TycoRC's Avatar
they are Z springs, for all that said it is not, I was suprised that it dropped so much, they are 06 Z springs and shocks, Ive compared it to my sport tuned shocks and springs, the shocks seemed 1 inch shorter than my sport tuned shocks and same with the springs
Old Jan 29, 2008 | 05:12 PM
Rodrigo's Avatar
what version of the 06 350z ?,
there are diffrent 350z ,
Enthusiast ,Nismo Track ed. ( ithink is the lowest) , Convertible , Base .
Old Jan 29, 2008 | 07:36 PM
5150DS's Avatar
There are only two types of z springs, revised and un revised. Revised are from 04.5+.
Old Jan 29, 2008 | 07:39 PM
5150DS's Avatar
It is possible they are z springs and if they are, the person who sold them to you most likely cut coils. Look at the G sedan on z springs thread and you will see why everyone is saying you are too low for z springs.
If you want to fill the wheel gap get 20's.
Old Jan 29, 2008 | 09:45 PM
DaveB's Avatar
Those are not OEM Z springs. Either they've been modified (ie cut) or the owner lied to you. There is absolutely no difference in the ride of height of any year Z. The only changes were in spring rate, not length.
Old Jan 30, 2008 | 02:51 AM
TycoRC's Avatar
Cutting springs is no bueno, I was comparing my Sport Tuned Shocks vs. 350Z shocks with both springs installed. I put them side by side from the top hat to the bottom fork of the shock, The Sport Tuned Suspension was definitely taller than the Z suspension, about maybe half an inch to maybe about an inch. Springs are not cut, I pretty much took it of his Z and installed it on my Sedan, the ride feels great, but IDK why I am lower than what you guys think, I can put about a finger between the fender and the tire, bump stops were not cut nor are the shocks blown. Oh well.....
Old Jan 30, 2008 | 11:11 AM
canucklehead's Avatar
^ i certainly hope you are wrong about the springs being untouched. i am going to be installing Z springs off an '06 soon, but i don't want a drop like you realized. everything i have read to date, your post being the exception, indicates that a sport sedan will see ~0.75"-0.9" drop with the revised Z springs.
a 1.5" drop is almost double what others have reported, and would make getting your alignment back into spec nearly impossible without further mods. plus, it appears much lower than i would find comfortable in a sedan.
