Car going to either side when braking?
Old Feb 12, 2008 | 05:08 PM
denise1768's Avatar
Hi,
Depending on the road, when I break, I can can pulled to either side. Is this normal? I've never had this happen with any of my other cars/SUVs.
It only happens when the street is uneven (even slightly!) or bumpy.
I was driving on the highway and i had to break suddenly and it pulled strongly. I can't imagine this being normal.
Thanks for your help.
Denise
Old Feb 12, 2008 | 11:04 PM
G35Now!'s Avatar
Moderation-free
Originally Posted by denise1768
Hi,
Denise
I find this only happens when traffic load has worn ruts (channels) into the road, and the edges of the tires are catching in the sides. On flat roads, haven't had this happen.
Old Feb 13, 2008 | 11:08 AM
denise1768's Avatar
I even get it on flat roads when the road might lean to either side, even if it's not visible to the eye. It's not as bad a pull, but still a pull.
Old Feb 13, 2008 | 11:40 AM
Deezflip's Avatar
It's normal, I experienced it on my other vehicles...especially with aftermarket wheels with wider tires.
Old Feb 13, 2008 | 11:42 AM
Hi-TechG35's Avatar
You may want to check your tires and your tie rods.
Old Feb 13, 2008 | 12:22 PM
G35sedan03's Avatar
I get the same on bad roads, like mentioned above with the roads tracks from heavy traffic. also wouldn't tire inflation affect that too? if one tire has less air than the other could that cause it to pull either way? I keep my tires at 45 psi. just wondering if it would.
Old Feb 13, 2008 | 01:31 PM
Q45tech's Avatar
Why aligments specs have a maximum or cross wheel camber, caster, toe spec.
If the power on vs static vs braking thrust angle changes obviously the vehicle will pull differently.
Old Feb 13, 2008 | 04:33 PM
denise1768's Avatar
Thanks all for your help.
Old Feb 13, 2008 | 06:31 PM
Deepdiver's Avatar
could also be a faulty proportioning valve.
Old Feb 13, 2008 | 06:46 PM
denise1768's Avatar
I'll be bringing it for service soon so I'll get it checked out. It just doesn't feel right.
yassy
Aug 3, 2015 12:24 AM
itschuckster
Jul 25, 2015 08:07 AM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
mushu
Jul 15, 2015 03:55 PM
