Tein Basic's...
Old Mar 26, 2008 | 04:29 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by nycityinsomniac
Would tein basics with a 1 inch drop handle better than my s techs that have a 2 inch drop? prob a dumb question.
Also how much of a drop can you do with the basics to get NO negative camber?
They'll handle a little bit better just because of the fact that the springs and struts are setup to work together. The stock struts werent designed to work with a 2" drop so they wont work as good but you still get decent handling because of the cars lower center of gravity.
It is physically impossible for you to run 0 camber (even with front and rear camber kits) with that aggressive wheel and tire setup you have on your car. And i can gaurantee that with only a 1" drop instead of the 2" drop you have now, your wheels will stick out and not look nearly as good.
-GP-
Old Mar 26, 2008 | 04:42 AM
dvsmeth0dz's Avatar
I installed my basics a few months ago and so far no noise from the suspension. the ride is a bit stiffer than the stock sport suspension but i like it
I would think the basics would handle better than the stechs considering that you get the shock to match the spring...right? as far as the drop w/ no negative camber, i don't think you can get too low without some negative camber. i've raised my car 2x since the installation because the camber looked way to crazy. looking at the pics of your car, yours look lower than mines.
Old Mar 26, 2008 | 04:55 AM
redlude97's Avatar
A better question would be how did you get a 2 inch drop out of the stechs? Cutting coils?
Old Mar 26, 2008 | 07:36 AM
theGster's Avatar
although i am new and did a lot of research i am wondering the same. 2"??
Old Mar 26, 2008 | 07:01 PM
spinn's Avatar
someone told me that you could go as low as about an 1" before you need a camber kit with the Basics.
Old Mar 27, 2008 | 06:39 PM
atownpdx's Avatar
Zero noise on my BASIX
Old Dec 29, 2008 | 10:09 AM
Roguewolf's Avatar
REVIVAL!!! lol
So basics are lower than s-techs? cuz i was told u could go as low as 2. 1/2'' while the s-techs only get 1.5'' or am i mistaken?
KruZZe
Feb 27, 2023 05:04 PM
Learned Hand
Oct 1, 2015 09:02 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
