Are you running a Richie's V1 or V2? Oh, and looks so much better with the new stance!!
Jeff92se
Red Card Crew
close
- Join DateMay 2005
- Locationɐʍ 'ǝlʇʇɐǝs
iTrader Positive Feedback100
iTrader Feedback Score(24)
Liked:585 Times in 498 Posts
V1 I guess. I think the V2 is polished.
Thanks. I'm glad I waited for the Konis. The handling is great.
Front still sits a bit higher than the rear, hopefully it settles a bit, but you can always add a spacer on top of the rear springmount to even it up better. Looks great compared to that 4x4 monstrosity on the first page
Jeff92se
Red Card Crew
close
- Join DateMay 2005
I "think" it looks like that because the 245-40-19 is 1.5% bigger than stock and the 225-40-19 is a touch smaller than stock.
Quote:
Z fronts / Coupe rear springs
Lower rider show for Ernie
Stud from hell!. Freakin' close to the Richie bar mounts!
Ya. . .that looks pretty nice.Originally Posted by Jeff92se
Pics: Z fronts / Coupe rear springs
Quote:
Good point, what are you going to run next time around on tires?Originally Posted by Jeff92se
Jeff92se
Red Card Crew
close
- Join DateMay 2005
Ideally 235-40-19s all around. But I might bid on some ps2s in all 245-40-19s. the slightly larger size doesn't excite me acceleration-wise but I don't know if that's the reason or because the re050s weigh like 27 frickin' lbs each!
Jeff92se
Red Card Crew
close
- Join DateMay 2005
Thanks Swivel.
Update: Not that anyone really uses Konis + the richie bar but I took a thick screwdriver and bent the richie strut bar brackets where they cross the threaded Koni strut stud. Simple thing and doesn't affect the ability to get at the strut bolts
how much negative camber are you running.
I have a feeling I may have an issue with the rear 255s. The kumhos look a bit wider than most 255s (5mm
or so)
My rear lips are rolled flat, I have a 35 series tire....I wonder with 1/2" rear drop if I would rub...I guess this is where you run negative camber
I went with this size b/c klub head and gixxersteve have this size tire on the rear with no issues
I'll try and post pics soon.
or so)My rear lips are rolled flat, I have a 35 series tire....I wonder with 1/2" rear drop if I would rub...I guess this is where you run negative camber
Jeff92se
Red Card Crew
close
- Join DateMay 2005
have no idea. you want me to take a pic of of the rear tire so you can kinda see?
what is homoz is you not showing up to the golden gardens meet. Tito even had a present for you. LAME!
Jeff92se
Red Card Crew
close
- Join DateMay 2005
Yeah, snow on my street, had to coach @ 1 that day. Day after a wedding reception. Daughter didn't sleep well etc...
What was the present?
:scurred:
:scurred:Registered User
Take a look and let me know, sig has tire sizes and fender lips are rolled.
thanks
I want to make sure I'm not rubbing with the g cpe rear springs.
w/ 1/2"drop, 35 aspect tires, neg. camber and I should be ok
want a z front/cpe rear
z front(g front)/stock rear
