Lots of brake squeal...
Old May 25, 2009 | 02:55 PM
digitalgulby's Avatar
Wow this got brought back from the dead! I changed my pads over a year ago!
Old May 25, 2009 | 03:55 PM
BH818's Avatar
well this is for, if you still have brakes left on the pads and it is squealing
Old Jun 16, 2009 | 12:11 PM
Balkranjit's Avatar
just wanted to comment. i have the brembos, resurfaced rotors all around and fresh pads all around. slowing down i hear the squeal bad, just the back left. So i took them apart and lube them up good. but i noticed the shim on the left rear showed signs of grinding. I swapped shims left rear to right rear. and the noise went from the back left to the back right. so i know its a bad shim.
Does anyone know if you can buy shims seperately or you have to buy another set of brakes?
lost the lock key same time, ouch.
Old Oct 20, 2009 | 07:43 PM
blAk mAx's Avatar
Originally Posted by BH818
If u see that you still have brakes left on the pades, the way to fix the squeal is to use a air compressor and blow all the brake dust out. that always fixes it, trust me you dont even have to take the rims off just blow the dust out good
going to try this, i recently came into the same problem.. i have hawk ceramics
Old Oct 20, 2009 | 10:21 PM
BH818's Avatar
did u guy silicone compound on back of brake pads?
Old Oct 20, 2009 | 10:36 PM
blAk mAx's Avatar
i did..wonder if i washed any of it off at the car wash
Old Oct 20, 2009 | 10:57 PM
BH818's Avatar
idk but mine is doin the same thing, I used the air compressor and blow out a lot of brake dust
mine is rear right only
I'm goin to take the whole thing out (calipers and rotors) and clean the whole thing that should fix it
Old Oct 21, 2009 | 12:02 AM
G35Gus's Avatar
I've got an 04 coupe with Brembo's I replaced out the front pads about 2.5k? ago with EBC greenstuff pads, ever since I've had my car back up here in MI when coming to slow stops my right front side highly squeaks..I took off the wheel and pads the other day cleaned all the dust off/cleaned em up etc..put the gel on the back of the shims yet still now they squeak, I'm getting very annoyed with it.
Old Oct 21, 2009 | 08:34 AM
obsdnoblivion's Avatar
Mine was doing this even with the brake goo on the back of the pads between the pad and that shoe clip thing some time after I had originally put the pads on. What do you call it? I took the rotors off and put them back on and it was doing it. Anyway, it eventually went away.
Jiggerjuice
Oct 5, 2015 02:33 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
itschuckster
Jul 25, 2015 08:07 AM
mushu
Jul 15, 2015 03:55 PM
