alignment specs - sedan, coupe or 350z???
Old Apr 16, 2008 | 02:51 PM
fronypony's Avatar
I have an 04 sedan (non-sport) and i'm installing full revised 350z suspension. My question is when i go and get it aligned, which specs am I going for, sedan or 350z? I know the suspension drops it ~1" so I am going to try to get away with not using camber kit, unless its too bad. Thanks in advance.
Old Apr 16, 2008 | 02:58 PM
Klubbheads's Avatar
more negative camber means extra grip at the limit. That is why 350z alignment specs are more agressive. So it is all up to u what u want. Ur toe and caster should be within specs. I personally would not go anything higher (meaning less agressive) than -1.0 rear camber.
Old Apr 16, 2008 | 03:08 PM
fronypony's Avatar
cool, I kinda figured it was all personal preference. While on the topic, are rear camber kits and rear adjustable toe arms the same thing? Can you use both pieces at the same time? Does one kit do both? A little confused about this.
Old Apr 16, 2008 | 03:09 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
FWIW...
You should only post your question in one place.
Then link it in other posts if you feel the need.
Old Apr 16, 2008 | 03:12 PM
fronypony's Avatar
^ok got it, thanks...deleting
Old Apr 16, 2008 | 04:45 PM
bigc's Avatar
Wings Nation
there are camber arms and there are toe arms (most people just get the toe BOLT kits). you'll likely need the camber arms and at least a toe bolt kit to get your rear within reasonable specs. I believe SPC kits their camber arms and toe bolts together...hit up gruppe-s or THMotorsports who are both vendors on the site.
Old Apr 16, 2008 | 04:54 PM
naughty240's Avatar
I have similar set up on my 03 sedan. I have the SPC rear camber arms. Very easy to install and cheap money too. Here is a DIY walkthrough
in post #8 https://g35driver.com/forums/showthr...ear+camber+kit
Old Apr 16, 2008 | 07:55 PM
Jeff92se's Avatar
Red Card Crew
You needed camber arms w/ Z springs? What was your before/after camber settings on your sedan and Z springs?
Old Apr 16, 2008 | 08:07 PM
naughty240's Avatar
I had mine alligned at the dealer mainly because I was getting free compression rods and radiator. The tech told me it was in factory specs. I didnt ask for a print out.
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
