HELP! Best Springs for stock ride???
Old Apr 22, 2008 | 06:44 PM
05GRide's Avatar
Opinions on spring rates needed!!
Hey guys,
Just got new wheels on my car - 19x9.0 + 18 with 255/35/19 front and 19x10.5 +23 with 285/35/19 rear. I want to know what springs are the best to eliminate the wheel gap over the stock height and bring the tire right up to the fender line. I have an 05 coupe 6MT with sport package (higher spring rates). I also want to make sure I don't compromise any handling or really soften the ride that much. Is it necessary to keep the spring rates about the same as stock in order to accomplish this?
I've looked through the sticky but want the forums personal opinions. I know everyone loves the Tein springs, but they have softer spring rates so I'm hesitant. Any other economical brands recommended??
So post up opinions please!! I'm looking to close that wheel gap, nice stance, and keep the aggressive sport package ride.
Old Apr 22, 2008 | 06:49 PM
lekker_droom's Avatar
man, just go with coilovers. springs rarely sit even. If your worried about price Ground Control makes some reasonable priced coilovers.
Old Apr 23, 2008 | 07:36 PM
05GRide's Avatar
Come on guys I've been reading through the sticky on here all day.... I'm just curious what setups everyone has (springs/shocks vs. coilovers) and how I can accomplish what I'm looking for. I want a ride that feels slightly stiffer than stock oem sport and would prefer to not have to dish out the full price of a coilover set. I intend on getting the rear camber kit and can do front if necessary but would like to avoid this.
Old Apr 24, 2008 | 03:02 PM
irishsig's Avatar
I have been doing weeks of research for the same thing and have come to the conclusion that I will most likely need to go to a meet in order to experience what the diff setups feel like. Everyone is going to have their own opinion on what is too hard or too soft of a ride. Right now it's looking like a good setup that is close to the sport suspension feel will be over 2k after camber kits, install and wheel allignment. Personally I'm leaning towards TEIN CS or HKS LS. Anyone, correct me if I'm wrong.
Old Apr 24, 2008 | 03:44 PM
Tulsa Rev-Up's Avatar
Tein CS FTW!! While I DO NOT have these, ive heard nothing but great things about the comforts, just my .02
Old Apr 24, 2008 | 03:58 PM
redlude97's Avatar
They do????????
Old Apr 24, 2008 | 04:01 PM
redlude97's Avatar
OP: Its going to be hard to get a drop that eliminates all the fender gap while maintaining a stock ride beacuse of the inherently short shock travel in the OEM suspension. Coilovers would be your best option. Tein Basics would be a good choice in this case. IF you are deadset on springs, then 350z S-techs would be a good option although there may still be some wheel gap, especially in the rear. A rear springmount modification may have to be performed to get rid of the wheel gap in the rear
Old Apr 24, 2008 | 07:52 PM
05GRide's Avatar
Redlude, thanks for the info. Do the S techs have a similar ride to stock sport suspension? Some wheel gap is okay as I don't want to be scrapping everything. Ideally, I want to level the ride out so the rear sits about the same height as the front. Springmount mod would be fine. I know that S techs would need the front camber kit as well correct? For sure the rear...
I know the Tein CS and HKS LS are a great set up and are height adjustable. Are the Tein Basics ride height adjustable? I'm trying to keep everything under $1K, is this possible. Just need something that looks good on those new wheels!
Thanks for the inputs, keep em coming!
Old Apr 24, 2008 | 08:19 PM
redlude97's Avatar
Sounds like Tein basic fits your budget perfectly. They are height adjustable and slightly stiffer than the sports suspension. You can get a set of new plus a rear SPC/Eibach camber kit with the toe bolts for under $1k, and as long as you don't go too low in the front you should be okay without a camber kit, and you can eventually purchase one if you want to go earlier
Old Apr 25, 2008 | 01:00 AM
05GRide's Avatar
Thanks again for the info Redlude!! How much to the Tein Basic's typically run and can you suggest someone to PM on here about it? How low can you drop a coupe over stock until you need the front A arms and camber kit, keeping the camber in spec and not running through my tires?
Also what the heck is the difference between the Basic's and the CS since I know the Tein CS typically runs at around $1500?? Other than the fact that the Basics are not dampening adjustable. Just curious how the Basic's are so much cheaper....
Do you think going with 350Z Stech springs w/springmount mod and Tokico D spec shocks is better than the Basics?
Old Apr 25, 2008 | 01:18 AM
redlude97's Avatar
The difference is exactly that, the CS has dampening adjustment and overall better valving. As to whether the basic vs s-tech/d-spec configuration is better, it depends on what you are looking for in terms of the suspension. The basics allow height adjustment so you can get the perfect drop height you are looking for, but the s-tech/d-spec combo has dampening adjustment so you will have better handling performance. IMO, i would just go with the basics unless you are going to spend the time fine tuning the d-specs for optimum performance
Old Apr 27, 2008 | 09:29 AM
Gilley's Avatar
I liked the ride comfort and drop that I had with my coupe when it was on 350Z S-Techs and adjustable Tokico 350Z D-specs (DSP-9). I did not need to do the springmount mod.
As lekker droom stated above, springs rarely sit even, so I changed to BC Racing coilovers (and since my G sedan needed new suspension which is where the S-Techs and D-Specs went) and the ride is essentially the same, but I can adjust the ride height and the dampers are adjsutable. You can get a set of BC Racing coilovers for about $1K shipped.
BTW, the ride in the sedan significantly improved with the D-specs.
Daniel k.
Nov 3, 2015 09:52 AM
Mignav01
Aug 22, 2015 03:12 AM
smartin0924
Aug 13, 2015 07:29 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
