BBK with out SSline?....any bad?
Old May 1, 2008 | 10:00 PM
ELE's Avatar
ELE
like the title~ i just got a great deal on a used Rotora BBK 6 piston 355mm~ and im just wonder if i require the SSline in order to make it work?or i can use the stock one?...........thxthx
Old May 1, 2008 | 10:09 PM
chenG35's Avatar
I would really not recommend it.. the front SS lines cost around 100 new.. or you can get used F+R SS for 100 right now in the "brake" section. So if you've already spent the $$ for BBK.. why reduce its performance to save 100 bux?
Old May 1, 2008 | 10:56 PM
Capthook's Avatar
I think the OEM rubber lines will not work. My brakes needed the line.
Old May 1, 2008 | 11:06 PM
Dan_K's Avatar
Probably won't work as the connectors are most likely different.
Old May 2, 2008 | 02:53 AM
ELE's Avatar
ELE
i pretty sure they will fit..~~cuz i got one extra pair of stock line~...~ and i just try to connect it ~apparently they fit~, i will take some picture~
for performance~ i dont' need it,...haha just want to show off~~ those BBK 6 piston 355mm weight like a ton@@, im very curious about the power to weight radio , by stopping it faster or slower ur car down by tons of weight added from BBK...hahaha
picture update soon^^~ thx for the help ~
Old May 2, 2008 | 03:31 PM
chenG35's Avatar
haha adding weights on brakes actually makes your car go slower and stop slower.. cuz there's more weight when the force is the same, results in lower acceleration/deceleration
but they sure look sweeeet
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
