What springs would you recommend rolling on 20's??
Old May 2, 2008 | 02:54 PM
dreyG35's Avatar
Hey everyone, I figured i'll take the cheaper route and just buy some springs to lower my coupe eventually. I'm rolling on some rimes that are similar in width to the 19' oem ray rims, but 1in larger in diameter (245/35/20). What spring would you recommend for a low enough drop where fender rolling wont be necessary, no rubbing, and about 1 (possibly 2) fingers fitting in between the fender and tire all around....
I'm thinking of going with the Tanabe df's....
Any advice would be awesome!! Thanks
Old May 2, 2008 | 03:48 PM
Sportcoupe35's Avatar
Depends on the year of the car but I think for 03-04s the 350z OEM springs would be a great fit.
Old May 2, 2008 | 04:47 PM
SteveBlake's Avatar
Do you have a coupe or a sedan?
Old May 2, 2008 | 05:52 PM
JTG35's Avatar
I just order some 350Z HTechs for my 20s on 05 Coupe. After doing so much researches I decided to go with Tein with a Moderate drop. I don't want any rubbing or rolling fender as well as dealing with camber issues. Z HTechs is the way to go.
Old May 2, 2008 | 07:38 PM
BadBoy06's Avatar
You will still need a rear camber kit (SPC works.)
Otherwise, plan on replacing threads often.
Hopefully, you ordered the Z H-Techs, they are pretty close
to the rear spring rate and fronts are a little bit stiffer then OEM
sport suspension.
Old May 2, 2008 | 07:44 PM
dreyG35's Avatar
I just ordered some Tanabe DF210 springs. Drops: front 1.7in & rear 1.3in . I have rear cambers so that should be good. You think I might need front cambers as well? After adding the 20's, it did lift the car up slightly so a 1.7 inch drop won't be too slammed. What do you guys think, would I have to order some front cambers? Cuz unfortunately I recently sold some I had ....
Old May 2, 2008 | 08:23 PM
Calvin's Avatar
Overglorified Altima
Yep.
Old May 2, 2008 | 08:36 PM
JTG35's Avatar
sport suspension.
Yep, I ordered the Z H-Techs. How long you think the threads is going to last if I don't have rear camber kit? Hopefully it won't wear out that quick becuase I might sell the GT-C along with ok tires threads.
Old May 2, 2008 | 10:02 PM
SteveBlake's Avatar
You dont even need a rear camber kit for the Z H Techs, i have them and im rollin on 20's. My rear camber is perfect, it's the front you gotta worry about.
Old May 2, 2008 | 10:28 PM
BadBoy06's Avatar
I would definitely do the spring mount mod for the rear. Otherwise your rear will be up and not leveled. After that I would be extremely surprised if your camber was perfect. The fronts really have no adjustment so you will be out -1or2* You may be fine without the mod but doubt it.
Old May 2, 2008 | 10:44 PM
LightsOut's Avatar
SIETESG
im dopped on z h techs i did not do the spring mount mod and i car has an even dropp.
my alignment was able to be put back to stock setting all four wheels
Old May 3, 2008 | 12:03 AM
JTG35's Avatar
I hope mine can come out like yours but we'll see.
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Batfinity
Intake & Exhaust
Sep 9, 2015 09:21 AM
philthethrilloh
Sep 9, 2015 01:25 AM
Detailed Image
Sep 8, 2015 02:42 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
