Tein EDFC VS TANABE TEAS ~~~ which one is better
so i just bought a set of Tein CS+ edfc and my friend picked up a set of tanabe sustec pro 5 + Teas, and the owner of the shop who sells both tanabe and tein(his a direct dealer) keeps on saying how ****ty the edfc is and say stuff like how much better the teas is, so I am just wondering if anyone have any experience with both? the owner said the sustec pro 5 would fit my car but it just need a little moficication....any thoughts on this??
Well, the teas is able to be programmed to adjust damping according to speed ( when hooked up to the vehicle speed sensor ) which is supposed to be pretty good. The edfc is only manually adjustable so while it could be programmed, adjusting on the fly wouldn't be advisable.
Personally I think both systems are kinda bs, the only thing I like about them is the fact you don't have to get dirty adjusting when adjusting the damper settings. Changing the damping of the vehicle while racing or driving mid turn seems counter productive, I'd rather have the suspension set one way, and be predictable rather than changing mid corner. Suspension bling...
Adjusting on the fly with the EDFC is no big deal. You can set it up to double the sensitivity with adjustments, from 16 to 32-way. The TEAS has 4 preprogrammable buttons, while the EDFC has 3. The speed-sensing feature of the TEAS sounds interesting, although I haven't experienced it firsthand.
Most owners of coilovers set their suspension once, and never change it again. Others might play with it a little bit, while very few actually get it dialed in correctly. Having the convenience of either of these systems means that you can make adjustments very quickly and easily. It's especially important for G35's, since you usually have to drop the rears to adjust them. You can't access them the way you can in the 350Z.
The EDFC is perfectly fine. Yur buddy is an a$$ clown for bashing the EDFC. I don't want a suspension that adjust according to speed. I want to adjust it myself. The EDFC is an amazing peice.
-Sean
-Sean
-Sean
Which is better?
We simply don't have the right info to form a opinion.
Some things that come to my mind.
CS is monotube
Pro Five is twin tube
Tein has a history of adjusting rebound and not much compression, we don't have a shock dyno yet for Z app yet so,...
Pro Five adjusts rebound, yet makes little change on compression. Based on the dyno they posted here and let's be realistic, I highly doubt it's a dyno of a G or Z application http://www.tanabe-usa.com/coilovers/SEVEN.asp#shockdyno I would not want to run them on the softer settings and I doubt I would ever be happy with their compression damping no matter the setting. Twin tubes can have difficulty generating higher levels of compression damping, not really suprised. Then again, we don't know what vehicle app they dyno'd.
Having a system that adjusts damping according to vehicle speed will only be as beneficial as the dampers ability to deliver in the first place
CS is monotube
Just got a ride yesterday in the Tanabe coils and the dampening control is actually pretty damn cool.. HUGE difference from soft to stiff.. much bigger difference then the TEINs.. but completely programmable where you should be able to have it not adjust as you go faster.. just stay on different settings you want..
pretty pricey system.. but damn its pretty good =)
thats just my thought from being in it
- Eric
- Eric
I forgot to add, you can have it start at specific settings and it'll scale up with speed too. For instance, if the fronts are on 4 and rears are on 6, as you accelerate to 40mph, it'll step up to 5/7 then 6/8, etc each 5mph. For cruising around town, I've used 1/3 with "speed adjusting" on, and it's way comfy when just cruising. . .and then when you speed up to go around corners, it stiffens. It's fun. (albeit not true "active" since it's not adjusting based on shock/rebound.)
In actuality, I think your friends dealer is pushing the TEAS because it costs more, especially in conjunction with the necessary coilovers. You can't go wrong with either system, although I'd choose the Tein Mono Flex over the CS.
edwinisdumb15
SOCAL Meetings & Events
Mar 4, 2016 10:45 AM
