03-04 RB OE BBK Question
Old May 15, 2008 | 08:27 AM
Mmagic76's Avatar
Had my mechanic install Racingbrake OEM BBK, mated with PBR DP pads. I noticed a bit of brake pad squeal so I picked up a tube of Synthetic Brake Caliper grease and attempted to take the pads off. Cleaned everything and applied the new grease. I've never worked on brakes before.
After putting it back together, I noticed vibration at moderate speeds when braking.
Rotors are new, pads are new, so the rotors are not warped b/c there was no vibration previous to me taking it apart last night.
What could have caused this? Overtightening of the caliper bolt? something else?
Thanks.
Old May 15, 2008 | 04:04 PM
Hotdawwgman's Avatar
did you pump your brakes before starting the car? did you make sure everything was buttoned up right?
Old May 15, 2008 | 04:06 PM
5150DS's Avatar
Maybe he overtorqued your lug nuts and warped the rotor.
Old May 15, 2008 | 04:48 PM
w33ps's Avatar
Got pics of the setup?
Old May 16, 2008 | 09:29 AM
Mmagic76's Avatar
Pumped brakes, yes, torqued caliper bolt to 22ft-lbs, torqued lug nuts to 85ft-lbs (cross bolt torquing).
The thing is, I don't think I warped the rotors b/c I don't feel any vibration at any other speeds except around 30-40 miles.
I'll try to take some pics tonight.
Old May 17, 2008 | 07:10 PM
ttrank's Avatar
Grocery getter
Only that speed sounds more like a tire balance issue.
Old May 17, 2008 | 08:48 PM
gEE805's Avatar
yup i agree....
as far as the other comment....how can you warp a rotor from over tightenin them??? serious if they warp due to that dont you think its a lil unsafe in that case??? I would hope the bolts break from tighten it to tight
Old May 21, 2008 | 12:07 PM
5150DS's Avatar
Originally Posted by gEE805
yup i agree....
Here you go smart guy. http://www.innerauto.com/Auto_Part/Brake_Disc/
Because of the stress that brake discs can experience it can be damaged in one of these three ways, they can warp, scar or even crack. Warping is caused by the heat generated from friction. The heat softens the metal which causes it to be reshaped. Another cause of warping is caused when the overheated disc is immediately cooled. This happens when a clamped disc is immediately released and is immediately cooled down. Improper torquing of lug nuts can also cause warping.
Old Jun 14, 2008 | 08:26 PM
gEE805's Avatar
smart guy here again. .. rotors are warped due to the type of pads and the heat it causes on the disc man. Why would over tighten the studs cause it to warp rather then breaking the wheel stud off when over tightern them like any other bolt/nut when is over tightened?? And the link you posting is an Ad to sell items. haha
You might be right? maybe 100% or maybe not but I'd like to see some R&D on that type of stuff since i like to learn about new information rather then reading some ad
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
neight
Aug 2, 2015 03:01 PM
mushu
Jul 15, 2015 03:55 PM
