Tein Basic vs Tein CS
Old May 18, 2008 | 05:29 PM
syshs's Avatar
Some questions about Tein Basics and Tein CS... just want to make a informed purchase.
1. Tein Basic Coilover setup, you can ONLY adjust the height of the coilovers, not the stiffness (damping) of the struts.
Is that a true statement?
If so, how is the stiffness on a range of 1 to 5 (5 being extremely stiffer compared to stock)?
2. Tein CS Coilover setup, you can adjust height of coilovers and stiffness of struts.
If so, to do that, do you have to have the EDFC installed? Can you adjust the height and/or stiffness (damping) without it?
Old May 18, 2008 | 10:44 PM
syshs's Avatar
Anybody?
Old May 18, 2008 | 11:09 PM
chilibowl's Avatar
Correct.
Couldnt answer that, someone with a set must answer that.
Correct.
Im pretty positive the dampening can be adjusted directly by physically adjusting some components on the coilover assembly itself. The EDFC is simply for the privilege of adjusting it in-car.
Old May 19, 2008 | 11:08 AM
BeerViper's Avatar
I think chilibowl hit it on the head. Adjusting damping on coilovers is normally done by turning a screw on the top of the shock tower, with EDFC it simply turns that screw for you electronically from within the car.
My TEIN FLEX setup is a pretty rough ride compared to stock even at the softest setting, but it was great at the track on Saturday
Old May 19, 2008 | 12:59 PM
EricIsKlumzyee's Avatar
CS rides crappy on our Gs
and the Basics are close to stock sport =)
TEIN Flex is stiff as hell
the CS and the Flex are both compadible with the EDFC but the dampening adjustments isnt as noticable as tanabe's ._. IMO it could be a bigger difference.. but CS on stiff mold = bad ride ._.
Old May 19, 2008 | 01:54 PM
syshs's Avatar
Nice, thanks for the good input guys... yeah, I want something a lil stiff.
So, Basics and CS are out of the window....
Now, its Tein Flex vs Tanabe vs Bilstein.
I will do some research on them.
Thanks again.
KruZZe
Feb 27, 2023 05:04 PM
Learned Hand
Oct 1, 2015 09:02 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
